Happy MMU3 User
I got my MMU3 for the MK4 about two weeks ago and after 36 hours of printing the parts, it is all together and up and running.
I had one assembly error that I fixed (I didn't tighten down the lock screws tightly enough on the pulley assembly)
I just finished my third multicolor print with 365 color changes without a single glitch.
The picture is of a puzzle box I downloaded from printables.com. It was a 26 hour print.
I am a happy camper. The MK4 w/MMU3 is (knock on wood) functioning without a glitch.
RE: Happy MMU3 User
I spent many frustrating hours on the MMU2 and MK3s+. I set it aside and waited for the MMU3. I have an MK4 now and assembled the MMU3 upgrade with the rev 4 parts and B buffer cassettes. It is all working well. YEEHAA. It works as a single machine, not 2 separate machines. The MMU3 has corrected the problems I had with the MMU2. Many changes seem small, like the bigger ID on the festo fittings, but added together it is a huge improvement. I think the nextruder improvements would benefit non MMU MK4 systems. See my MK4/MMU3 notes if you want more details.
With the MMU3 Prusa played its reputation, the right to error was no longer allowed, so much time lost and wasted filament with the awful MMU2.
As soon as I received the upgrade kit , I mounted it on my MK4 to test it, start with a 5 colors print with 220 filament change, then a second one also 5 colors with 480 filament change both in PETG, and and you know what! NOT A SINGLE ISSUE.
Forgotten the countless failures of the MMU2 that often resulted in a total inoperative device, and then sending the printed object to the trash.
Finally this endless waiting ends up with a device that works perfectly well, the filament tips are perfect, the purge blocks are lighter, there is apparently less waste.
MK4/MMU3 - VORON 2.4 350 Stealthburner
