Can a MMU3 change to another roll when filament runs out?
I have a MMU3 on order, I was wondering when I'm not doing multi color if I could set up two rolls of the same color and have it switch when one roll runs out? I'm used to CNC's that when tool life is reached, they switch to another similar tool and carry on machining.
RE: Can a MMU3 change to another roll when filament runs out?
Short answer is yes. Look up "Spool Join" in the manual. It has to be done on the front panel when you map the MMU3 slot to the sliced filament.
However, I've had limited success with this because most of the rolls of filament I have start their winding by pushing the filament end through a hole in the hub. That creates a near-90 degree kink in the filament right at the end, and for me it will refuse to be pulled through the PTFE tubing and causes an "air print".
There are automatic filament cutters but I haven't tried them. I try to be at the printer while the last layer of winding is being used on the first roll, and snip the filament next to the bend. Then it works great.
Look in the MMU3 manual (downloadable at https://www.prusa3d.com/downloads/manual/prusa3d_manual_mmu3_en_1_03.pdf) - page 47 section 8.3.1 for one method which allows continuous joining with all 5 slots, and page 49 section 8.3.7 where you can select which slots are joined, in addition to other colours.
The bent filament at the end of the spool has been driving me crazy lately. I've tried cutting the bent end off on some of the spools where the end is visible inside the spool and still have issues. I'll have to look into the automatic filament cutters.
a local company, in the UK, has cardboard reels which expose the end of the roll so that you can cut it off when you open the reel, so that you can print to the end without worry
Recently I found the Overture carboard rolls do not have a hard bend in the end and feed through the tube without a problem.
good to know...
prusa have also improved more recent spools
Joan
Hi, I just start using spool join with multicolor print on Mk3s+. Found that it can switch to another spool, but after colour change, it want to use again the first spool with. So it have to go again through the swap spool process.
The main issue i found here, regarding time waste for additional filament change, is that printer after detection of the end of filament, movees to the ccorner, swaps to next spool and makes a poop that sticks somewhere, like hotend, or print, or the cleaning tower and can make a collision with the nozzle.
Is there some sigh that someone is working on getting the function from 3.5 and abowe (with lcd screwn) to older printer to setup the spools in the printer computer or that it could be drawn from gcode and after change spool will stay on that one after next color change?
