3.0.2 Firmware for MMU3 (MK3S+, MK3.5)
Summary
- Information for the MK3.5 owners
 - Information for the MK3S+ owners
 - List of pull requests
This is the stable release of firmware version 3.0.2 for the MMU3 unit, primarily intended for the upcoming Original Prusa MK3.5. Further details are provided below.
This is an initial release containing updates to the firmware, enabling compatibility with the MMU3 unit and the Original Prusa MK3.5.
Please note, that this 3.0.2 release must be paired with an upcoming specific firmware version for the MK3.5. Once the printer firmware is prepared, it will be published on GitHub, with further instructions on how to use the MMU3 with MK3.5.
This firmware is primarily focused on adding support for the MK3.5. There are no changes for MK3S+ owners, therefore updating the firmware is not needed.
Nevertheless, there will be a possibility to update your unit, but please note that this 3.0.2 release must be paired with an upcoming specific firmware version for the MK3S+. Once the printer firmware is ready, it will be published on GitHub, along with additional information.
- Update trademarks wording by @DRracer in #296
 - Remove private and use Unit by @3d-gussner in #297
 - Redirect Question template over to GH discussions by @3d-gussner in #298
 - Add links to printer FW repos for reporting actual bugs or issues. by @vintagepc in #300
 - Add pr-size and stale actions. by @3d-gussner in #299
 - cut filament: remove two unused constants by @gudnimg in #305
 - Add Actions firmware build by @vintagepc in #304
 - Update CMakeLists.txt by @vintagepc in #311
 - Update PR size to show by @3d-gussner in #310
 - Fix cmake by @3d-gussner in #306
 - BFW-3317: New filenames for hex files by @3d-gussner in #307
 - Add cutLength register (0x23) by @DRracer in #312
 - Add RawProgressCode & ProgressCode::_cnt by @CZDanol in #313
 - @CZDanol made their first contribution in #313
Full Changelog: v3.0.1...v3.0.2
GitHub Link: https://github.com/prusa3d/Prusa-Firmware-MMU/releases/tag/v3.0.2
 / Knowledge Base
