Soluble support print setting not showing in prusaslicer
shaunlewis38
(@shaunlewis38)
Hi, I'm having some trouble figuring out how to use soluble supports in prusaslicer. In the MMU3 manual section 6.5.2, it shows 'SOLUBLE FULL' and 'SOLUBLE INTERFACE' as options in the print settings menu. However, these don't show up for me and I can't find how to add them. I've attached a screenshot showing that it looks like for me, and those options aren't there. How do I get these options?
For reference, I'm using PrusaSlicer version 2.7.4, a MK4 printer, and the MMU3.
Opublikowany : 17/04/2024 8:00 pm
Volker
(@volker)
RE: Soluble support print setting not showing in prusaslicer
For MMU3 / MK4 those profiles are not created or released. But you can try by yourself - might create some frustration. I was able to print with a special suport. I did not try with soluble interface. This is one of my next tasks.
To create a print profil got to the print settings and support material. On "Top contact Z distance" choose "0 (soluble)".
Then go to "multiple extruder" There are 2 items "Support material/raft/ " where you can choose the extruder (0 means automatic) where your support material is placed.
Then you need to create a soluble filament material. Take the values out of one of the MK3/MMU2 parts as a starting point.
Opublikowany : 18/04/2024 6:49 am
1 ludzie polubili
IG
 IG
(@ig)
I guess this would be how to create a non-soluble support as well, e.g using PETG support for a PLA print, or PLA support for a PETG print?
X marks the spot.
Opublikowany : 20/04/2024 2:46 am
rdr22804
(@rdr22804)
I have a mk3s+ and they  are not there for me either. Why put that in the manual if it's not true?
Opublikowany : 02/05/2024 2:18 pm
