					                		PTFE tubes: to cut, or not to cut? - Assembly and first prints troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/ptfe-tubes-to-cut-or-not-to-cut/</link>
                <lastBuildDate>Wed, 20 May 2026 09:52:11 +0000</lastBuildDate>
                        <title>RE: PTFE tubes: to cut, or not to cut?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/ptfe-tubes-to-cut-or-not-to-cut/#post-738238</link>
                        <pubDate>Wed, 26 Feb 2025 10:23:18 +0000</pubDate>
                        <description><![CDATA[I left the ones between the buffer and MMU3 untouched. I ordered some extra PTFE tubing and a cutter (it&#039;s very cheap) from AliExpress and used that for the lengths between the spools and bu...]]></description>
                        <content:encoded><![CDATA[<p>I left the ones between the buffer and MMU3 untouched. </p><p>I ordered some extra PTFE tubing and a cutter (it's very cheap) from AliExpress and used that for the lengths between the spools and buffer, since they differ according to my spool placement - so some longer then others. Packed the original ones away in a box just in case I need them in future. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>iftibashir</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/ptfe-tubes-to-cut-or-not-to-cut/#post-738238</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/ptfe-tubes-to-cut-or-not-to-cut/#post-737513</link>
                        <pubDate>Fri, 21 Feb 2025 14:49:31 +0000</pubDate>
                        <description><![CDATA[I had to cut mines because of space limitations where I have the printer, so the whole assembly is more compact.No problems. I&#039;ve used a sharp knife.]]></description>
                        <content:encoded><![CDATA[<p>I had to cut mines because of space limitations where I have the printer, so the whole assembly is more compact.</p><p>No problems. I've used a sharp knife.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Rui Guerra</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/ptfe-tubes-to-cut-or-not-to-cut/#post-737513</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/ptfe-tubes-to-cut-or-not-to-cut/#post-736769</link>
                        <pubDate>Sun, 16 Feb 2025 20:06:04 +0000</pubDate>
                        <description><![CDATA[If you cut one, and try it, you can still print a joiner sleeve and repair it if necessary I cut the tubes on my MMU2 and it worked better... regards Joan]]></description>
                        <content:encoded><![CDATA[<p>If you cut one, and try it, you can still print a joiner sleeve and repair it if necessary <br />I cut the tubes on my MMU2 and it worked better... <br />regards Joan</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>JoanTabb</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/ptfe-tubes-to-cut-or-not-to-cut/#post-736769</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/ptfe-tubes-to-cut-or-not-to-cut/#post-736728</link>
                        <pubDate>Sun, 16 Feb 2025 14:00:03 +0000</pubDate>
                        <description><![CDATA[Thanks.I&#039;ll follow your advice.]]></description>
                        <content:encoded><![CDATA[<p>Thanks.<br />I'll follow your advice.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Nick_Hacking</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/ptfe-tubes-to-cut-or-not-to-cut/#post-736728</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/ptfe-tubes-to-cut-or-not-to-cut/#post-736686</link>
                        <pubDate>Sun, 16 Feb 2025 02:09:00 +0000</pubDate>
                        <description><![CDATA[Get a tubing cutter, don&#039;t use scissors.  It&#039;ll leave a damaged end on the tube.  They are only a few dollars. 
As far as if you should cut them I have no idea as I didn&#039;t have an MMU.]]></description>
                        <content:encoded><![CDATA[<p>Get a tubing cutter, don't use scissors.  It'll leave a damaged end on the tube.  They are only a few dollars. </p>
<p>As far as if you should cut them I have no idea as I didn't have an MMU.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Brian</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/ptfe-tubes-to-cut-or-not-to-cut/#post-736686</guid>
                        <title>PTFE tubes: to cut, or not to cut?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/ptfe-tubes-to-cut-or-not-to-cut/#post-736652</link>
                        <pubDate>Sat, 15 Feb 2025 21:34:38 +0000</pubDate>
                        <description><![CDATA[Dear Experts,I&#039;m in the final stages of putting together my MK4S with the Original Enclosure and MMU3.Many of the flexible PTFE tubes that are to carry filament from the spools to the casset...]]></description>
                        <content:encoded><![CDATA[<p>Dear Experts,</p><p>I'm in the final stages of putting together my MK4S with the Original Enclosure and MMU3.<br />Many of the flexible PTFE tubes that are to carry filament from the spools to the cassettes seem to be very long and would be neater if trimmed.</p><p>With cutting being an irreversible operation, I thought I'd seek advice before getting the scissors out....  Should I?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/ptfe-tubes-to-cut-or-not-to-cut/#post-736652</guid>
