					                		Having wipe tower obstruction issues causing layer shifts - Assembly and first prints troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/having-wipe-tower-obstruction-issues-causing-layer-shifts/</link>
                <lastBuildDate>Mon, 08 Jun 2026 18:15:16 +0000</lastBuildDate>
                        <title>RE: Having wipe tower obstruction issues causing layer shifts</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/having-wipe-tower-obstruction-issues-causing-layer-shifts/#post-695601</link>
                        <pubDate>Mon, 22 Jan 2024 17:12:09 +0000</pubDate>
                        <description><![CDATA[I&#039;ve improved the situation drastically by experimenting with different filament profiles in Prusaslicer. Different color filament sometimes  requires different temps/fan settings.For me, in...]]></description>
                        <content:encoded><![CDATA[<p>I've improved the situation drastically by experimenting with different filament profiles in Prusaslicer. Different color filament sometimes  requires different temps/fan settings.</p><p>For me, increasing the PETG temperature to 240 from the default 230 solved my problems. Some colors did fine with extruder fans off, others needed the fans.</p><p>So I would recommend adjusting temps up/down and fans on/off until you find what works.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>mgantner</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/having-wipe-tower-obstruction-issues-causing-layer-shifts/#post-695601</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/having-wipe-tower-obstruction-issues-causing-layer-shifts/#post-695599</link>
                        <pubDate>Mon, 22 Jan 2024 17:02:58 +0000</pubDate>
                        <description><![CDATA[Hi, I am having the same issues with my wipe tower and it&#039;s a mess whilst most of the time the print is ok. I&#039;d like to change the nozzle position when changing filament so its a little high...]]></description>
                        <content:encoded><![CDATA[<p>Hi, I am having the same issues with my wipe tower and it's a mess whilst most of the time the print is ok. I'd like to change the nozzle position when changing filament so its a little higher. I think this would be the nozzle would be hot but not so closer to the tower until the filament change has been completed. No idea how to do that though :-) </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Mezzauk</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/having-wipe-tower-obstruction-issues-causing-layer-shifts/#post-695599</guid>
                        <title>Having wipe tower obstruction issues causing layer shifts</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/having-wipe-tower-obstruction-issues-causing-layer-shifts/#post-688498</link>
                        <pubDate>Sat, 09 Dec 2023 03:45:54 +0000</pubDate>
                        <description><![CDATA[Printing PETG a d the prints are looking good but the wipe tower is blobbing and stringing, which is causing nozzle obstructions and layer shifts.Anyone else having this problem? Suggestions...]]></description>
                        <content:encoded><![CDATA[<p>Printing PETG a d the prints are looking good but the wipe tower is blobbing and stringing, which is causing nozzle obstructions and layer shifts.</p><p>Anyone else having this problem? Suggestions?</p><p>Thanks!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/having-wipe-tower-obstruction-issues-causing-layer-shifts/#post-688498</guid>
