Adding MMU3 to Core One, what a nighmare
rphughesnj@icloud.com
(@rphughesnjicloud-com)
Utenti
I recently added an MMU3 unit to my Core One.  The experience was a nightmare.  Before I start getting negative I want to say I love my Core One.  It is a great printer.  My issues are only related to the MMU3 “upgrade”.
I ordered my Core One last December with the expectation of being to add multicolor printing with an MMU3 when it was released for the Core One.  I was replacing an Bambu X1C with an AMS and hoping to do multicolor printing without the “poop”.
My assembled Core One arrived in March. It worked great out of the box.  Absolutely no issues doing single color prints. Changing nozzles was a joy.  Great printer.
 In June, or so, Prusa released versions of the MMU3 for the Core One.  I placed an order.  After waiting 4 weeks without getting info about a scheduled ship date, I followed up with support via an online chat. They said there was a delay in shipping the units but they did know the cause of the delay.  This was six months after my original order of my Core One.  I was not a happy camper.
While looking at the Prusa site I noticed that they had an assembled MMU3 for the MK4s in stock.  The also had a MK4s to Core One MMU conversion kit available. Sounded like a good path forward.  I canceled my MMU3 order and replaced it the MK4s conversion option.
I assembled the kits without issue.  The MMU3 was already assembled but the buffer needed to be setup.  This was all external to the printer.  Internally the Nextruder needs to be modified. I was a bit pissed that I had to make these changes to a new printer.  Since Prusa were requiring these Nextruder changes for MK4s printers with MMU3 last year.  Why weren’t those changes incorporated into my printer at the factory.
I make the Nextruder changes and fired everything up.  After updating the printer and MMU3 firmware I was ready to try a print.
I tried to load the filament and was unsuccessful.  I chose a spool of PLA that was 2/3 empty. The curvature of the filament was such the it would not engage with the mechanism in the MMU.  This is the first time I ever encounter a problem with curves in filament. I thought, OK, old filament, try a new spool.
Nest i tried a brand new spool of dry Prusament PETG.  This filament had much  less curvature but it still got stuck.  Initially. It was stuck feeding around the pulley in the buffer.  I straightened it out and got past the blockage.  Then it got stuck in the MMU.  Again, more straightening needed.  After many attempts, I got the filament loaded. Way too much work to load brand new filament.
At one point, I thought I would bypass the MMU and use the external spool holder.  I researched how to do this and found a paragraph that said that you can do a single external spool print but the unload might fail and a manual unclogging might be needed.
Bottom line, by applying the Nextruder changes I have screwed up my printer. The MMU limits my printers to using 0.4 brass nozzle.  If I want to use a different nozzle, I have to use the external spool, but that may fail during unload. Oh, and loading filament into the MMU3 is a real pain due to filament curvature.
What a mess.
I hope the engineers at Prusa who are working on their Netgen solution have access to a Bambu printer with AMS.   It is a great example of how easy multicolor printing can be.
Postato : 01/08/2025 11:12 pm
GBMaryland
(@gbmaryland)
RE: Adding MMU3 to Core One, what a nighmare
Reading your story, pretty much is exactly the same as mine…
frankly, I’m pretty unimpressed because I’m having exactly the same problem. what’s even otter is that I’m not finding any data from other people posting online that they’re having exactly the same problem… I’m trying to figure out what could cause it. if not having straight filament is the actual issue that is a really cheesy design.
I’m still wondering if it’s operator error, but it is odd.
https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/mmu3-failure-to-preload/#post-767546
Postato : 21/10/2025 8:22 pm
Peter Kruisman
(@peter-kruisman)
Utenti
That MMU3 is the worst design ever. When the filament runs out, I don't get a notification. I had to put in new filament with great difficulty. The sensor detects that there's filament in the cartridge but refuses to feed it to the print head. If I select "retry," it throws the filament back out. The only thing you can do is reset the printer. What a waste of money.
Postato : 26/11/2025 3:37 pm
1 persone hanno apprezzato
Mike B
(@mike-b-3)
The filament path including the buffer and MMU3 is sensitive to tip shape.  If you have anything but a pointed or rounded tip it might catch on several things.
I made one of these https://www.printables.com/model/1099105-filament-tipper-v3-with-square-nuts-and-magnets and use it whenever the tip doesn't look right.  No issues as long as the filament doesn't have a sharp bend near the tip (i.e. within 50 mm or so).
Postato : 26/11/2025 9:41 pm
mnentwig
(@mnentwig)
Yes, I don't think curved filament is the root cause (not arguing your MMU is not working, just that something else is causing it). In the middle of a print, when filament gets retracted, it is always bent, coming from the spool. This is not a systematic flaw with the MMU.
However, many people swear by a mod that straightens out the last two centimeters of the PTFE tube for easier loading. Whether it's needed or not is another question (I have it printed but was too lazy to assemble after cleaning and continued working with the stock setup, just avoiding pulling on the PTFE tubes to the buffers).
I'd check pulley position, even if it's not a kit as in this case.
Postato : 26/11/2025 10:03 pm
Utenti
Frankly, I gave up on the MMU3.  I sold my Core One and went back to Bambu X1C and AMS (actually 2 units).  IMHO the Core One is a better printer than the X1C, but the new AMS 2 units are so much easier to use than the MMU3 units.  Hopefully the new INDX units Prusa recently announced will finally make multi-color printing on a Core One easy.
Postato : 27/11/2025 5:18 am
