Upgraded parts for MMU2.0
Strona 2 / 2
Sneaks
(@sneaks)
Re: Upgraded parts for MMU2.0
Thank you for sharing this! I just finished putting everything back together and it works awesome; so much cleaner. I had issues getting the square nuts into their slots, so I quickly hit them with a small torch and they went right in.
Opublikowany : 05/12/2018 6:33 pm
CybrSage
(@cybrsage)
Speaking of those small square nuts, anyone know where to buy new ones? I would pick them up at my local hardware store but I don't know enough about them, if it is possible to get square nuts there at all!
Opublikowany : 05/12/2018 6:37 pm
Sneaks
(@sneaks)
I purchased some off of amazon, however they are substantially thicker. Wherever you find them, make sure you check the thickness if you are using them in Prusa Parts.
Opublikowany : 05/12/2018 6:39 pm
CybrSage
(@cybrsage)
Do you know the specs of what you purchase?
Opublikowany : 05/12/2018 7:08 pm
davidsteinman
(@davidsteinman)
These are what I purchased on Amazon. Somebody else had probably posted them here before.
https://www.amazon.com/gp/product/B073SBNNZ7/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
David
Opublikowany : 05/12/2018 7:43 pm
Sneaks
(@sneaks)
The Amazon ones are 5.4x5.4x2.4mm: http://a.co/d/7uxdRKX
It looks like the openings on the printed parts are 2.1x5.6mm - I just found some square nuts on Ali-Express that are 1.8x5.4mm https://www.aliexpress.com/item/100X-THIN-Nut-M3-M4-M5-M6-M8-A2-STAINLESS-STEEL-SQUARE-THIN-NUTS-DIN-562/32892455789.html
Opublikowany : 05/12/2018 7:51 pm
Area51
(@area51)
Search for DIN 562; on eBay: https://www.ebay.com/sch/i.html?_nkw=din+562
Opublikowany : 08/12/2018 4:59 am
Kerry
(@kerry)
These are the thin ones I purchased and they match prusa's perfectly
https://www.amazon.co.uk/gp/product/B073SB766G/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
Albeit I am in the UK but using the description I am sure you can find them across the pond
Regards
Kerry
Opublikowany : 17/12/2018 10:44 am
Plugs
(@plugs-2)
Hi just one small question . What did you do with the Filament in the cable bundle as the middle screw on the new clip blocks that hole ?
Opublikowany : 02/01/2019 1:31 pm
Jbravo88
(@jbravo88)
Hi Pete, thank you for your question, the hole is present (unchanged) here's a closeup from different angles the hole is low enough that the screw hole misses it.
Opublikowany : 05/01/2019 4:34 am
Grimgrin
(@grimgrin)
Might be a little late, but the thickness you're looking for is 2mm. Initially got stuck with the thicker ones too; had to constantly file them down a fair bit if I needed to get any practical use out of them. I got these off Amazon too, and they've worked a treat:
https://www.amazon.com/gp/product/B018503K94/ref=ppx_yo_dt_b_asin_title_o08__o00_s00?ie=UTF8&psc=1
There are others, but I got these on Prime. Hope it helped.
Opublikowany : 11/01/2019 6:15 pm
Strona 2 / 2
