MMU V2 for only two materials
francisco.l2
(@francisco-l2)
Hi, is it possible to have the new MMU +MK3 for only two materials use?. In my case I wont be using it too much for colors, but yes for soluble materials.
Is it OK to remove the extra three TPFE tubes from the back of the MMU?. Do I need to let them mounted?. This question is related to printer "footprint" on the working table, as now I need more than twice of the original space for have it mounted,
Thank you!
Napsal : 03/11/2018 1:11 pm
Re: MMU V2 for only two materials
Hi Francisco,
you only need to mount the number of filament's / ptfe tubes/ filament holders that you intend to use!
so you can save space behind the printer.
Napsal : 03/11/2018 1:24 pm
francisco.l2
(@francisco-l2)
Hi Joan,
Thank you for your answer. I will remove the three extra TPFE tubes from the MMU.
Kind regards,
Napsal : 03/11/2018 10:59 pm
CybrSage
(@cybrsage)
This is the exact reason I bought one as well. 🙂
Napsal : 30/11/2018 6:54 am
