distance from filament sensor to extruder gears
I recently changed my mk3.5 out to a zorbiter setup. Now it will not load filament from the mmu to the nozzle. I am thinking that the distance from. the filament sensors to the gears has changed. Does anyone know where in the config.h file this distance is set at? I have measured 30mm from the sensor to the gears, and 70mm from the sensor to the nozzle
Opublikowany : 10/08/2025 12:16 pm
