Round Objects in flexible filament
I Have to Print this Thing 16 times.
But I can't geht it to print the Filament is a Inoflex 60 from BASF.
If I print it with the round part up the overhang from the round part is ugly.
If I print the round part down it is not printing at all.
I can't use support in the same Material because it is flexible and I will not get it off.
What could I do?
Veröffentlicht : 20/03/2020 3:24 pm
RE: Round Objects in flexible filament
Can you redesign the part to use a chamfer instead of a fillet for the side printed on the bed?
Veröffentlicht : 20/03/2020 3:53 pm
I had an object not dissimilar. Try adding a 45 fillet to the underside of the dome. And flip the print 180 deg
i3 Mk3 [aug 2018] upgrade>>> i3MK3/S+[Dec 2023]
Veröffentlicht : 21/03/2020 8:05 am
