Create multipart MMU print file from F3D
Markus
(@markus-6)
Hi all,
is there a simple way of only exporting a part of an F3D model for MMU priniting? In my concrete case, I have a model that consists of 12 bodies and 5 components (with 1 to three bodies each). Most of these are only for reference, I don’t want to print them. Of those I do want to print, one object consists of three bodies (main shell and two transparent windows) - and that’s the only one I need the MMU for. A second body could be printed in the same run using the MMU, the third body would be printed in an extra run (don’t want to mix up PLA  and TPU 🙂 ).
So, that’s three (four) out of ~20 bodies I actually want to print…. any simple/clean solution, or is the best/only way to export them all and later sort them out?
Posted : 30/06/2021 7:52 am
Lichtjaeger
(@lichtjaeger)
RE: Create multipart MMU print file from F3D
Export the shell and the two windows individually (to file, not to PrusaSlicer). Load the shell into PrusaSlicer. Right-click on the shell and choose "Add Part" to load the windows.
Posted : 30/06/2021 8:51 am
Markus
(@markus-6)
@lichtjaeger
Bingo! Works like a charm - thanks.
Posted : 30/06/2021 9:05 am
