wrong filament change on single color print
Brixsat
(@brixsat)
Hello, I have a prusa i3 mk3s with mmu2s.
Im currently printing a single color piece and randomly it asks for filament change to the same color like if i pressed the control and selected swap filament or something. It then ask's to confirm filament loaded ok.
I have times this does not happen (no change in gcode what so ever).
I am using octoprint.
What can it be?
Thanks in advance
Best Answer by Diem:
A simple check - turn off your filament sensor (lcd menu) does the problem stop, turn it on, does it recur?
If so your filament sensor needs adjustment or cleaning.
Posted : 16/09/2021 10:21 am
fhartmann
(@fhartmann)
similar behave ?
https://forum.prusa3d.com/forum/postid/507007/
Posted : 28/09/2021 9:23 am
Posted : 28/09/2021 12:37 pm
Brixsat
(@brixsat)
Thank you
Thanks that is the problem.
Really thank you.
Posted : 17/10/2021 5:58 pm
