Wipe to Infill Settings
FusionBolt
(@fusionbolt)
Does anyone know how the "Wipe to Infill" feature affects the purge tower size? Does it automatically reduce the size of the purge tower, or do you have to manually change the size of the tower?
Napsal : 13/01/2019 4:35 pm
Nikolai
(@nikolai)
Re: Wipe to Infill Settings
Tower size is being determined automatically based on many factors. Wipe to infill reduces the tower size as the infill can be used for wiping partially or fully.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Napsal : 14/01/2019 2:51 am
wipe to infill mainly affects the tower density. the waste tower top surface needs to be big enough to accommodate all colour changes on the top layer
there is no infill available for waste in the top layer
Joan
Napsal : 14/01/2019 9:16 am
