					                		Spec for MMU2 springs? - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/spec-for-mmu2-springs/</link>
                <lastBuildDate>Sun, 14 Jun 2026 06:44:19 +0000</lastBuildDate>
                        <title>RE: Spec for MMU2 springs?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/spec-for-mmu2-springs/#post-790787</link>
                        <pubDate>Tue, 28 Apr 2026 22:06:07 +0000</pubDate>
                        <description><![CDATA[Take a look here]]></description>
                        <content:encoded><![CDATA[<p>Take a look here:</p><p>https://www.federnshop.com/de/produkte/druckfedern.html</p><p>wbr,</p><p>Karl</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>karl-herbert</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/spec-for-mmu2-springs/#post-790787</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/spec-for-mmu2-springs/#post-780772</link>
                        <pubDate>Wed, 04 Feb 2026 17:29:29 +0000</pubDate>
                        <description><![CDATA[Hallo! could you please share the link to the springs? best regards from Germany as well :-)]]></description>
                        <content:encoded><![CDATA[<p>Hallo! could you please share the link to the springs?</p><p> </p><p>best regards from Germany as well :-)</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>arbornoctis</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/spec-for-mmu2-springs/#post-780772</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/spec-for-mmu2-springs/#post-612523</link>
                        <pubDate>Mon, 04 Jul 2022 18:48:49 +0000</pubDate>
                        <description><![CDATA[I use springs specifications like this: (not Prusa original):innerdia.: 3.3mmouterdia.: 4.9mmspring steel 0.8mmlength: 15mmallen screw length: 30-35mmI unfortunately only know German sources...]]></description>
                        <content:encoded><![CDATA[<p>I use springs specifications like this: (not Prusa original):</p><p>innerdia.: 3.3mm</p><p>outerdia.: 4.9mm</p><p>spring steel 0.8mm</p><p>length: 15mm</p><p>allen screw length: 30-35mm</p><p>I unfortunately only know German sources or Prusa, but maybe you can find a spring store in your area.</p><p>wbr,</p><p>Karl</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/spec-for-mmu2-springs/#post-612523</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/spec-for-mmu2-springs/#post-612450</link>
                        <pubDate>Mon, 04 Jul 2022 13:38:05 +0000</pubDate>
                        <description><![CDATA[On a related note, I would strongly recommend printing and installing those thumbscrew extensions, available in the Prints section, and barely visible in the photo below.These make opening t...]]></description>
                        <content:encoded><![CDATA[<p>On a related note, I would strongly recommend printing and installing those thumbscrew extensions, available in the Prints section, and barely visible in the photo below.</p><p>These make opening the unit MUCH easier and reduces the chance of springs and bolts flying across the room.</p><p>You will need slightly longer bolts, available from about anywhere, to make these work.</p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2020/07/mod3.jpg"><img class="alignnone size-medium wp-image-40501" src="https://forum.prusa3d.com/wp-content/uploads/2020/07/mod3-600x427.jpg" alt="" width="600" height="427" /></a></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>jsw</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/spec-for-mmu2-springs/#post-612450</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/spec-for-mmu2-springs/#post-612447</link>
                        <pubDate>Mon, 04 Jul 2022 12:46:38 +0000</pubDate>
                        <description><![CDATA[Well, just try what you find at home or local store. It must only fit to the bolt and be long enough to be able to adjust the force. Tip: For hard filaments a spring from pen doesn´t work, y...]]></description>
                        <content:encoded><![CDATA[<p>Well, just try what you find at home or local store. It must only fit to the bolt and be long enough to be able to adjust the force. Tip: For hard filaments a spring from pen doesn´t work, you will need stronger one.</p><p>I had a different spring issue with printing softer filaments like flexible fil or PP and I had fixed it with softer spring from a pen.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Petr</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/spec-for-mmu2-springs/#post-612447</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/spec-for-mmu2-springs/#post-609906</link>
                        <pubDate>Wed, 15 Jun 2022 13:15:28 +0000</pubDate>
                        <description><![CDATA[did you ever figure this out? I&#039;m in the same boat.]]></description>
                        <content:encoded><![CDATA[<p>did you ever figure this out? I'm in the same boat.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>walkitinkid</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/spec-for-mmu2-springs/#post-609906</guid>
                        <title>Spec for MMU2 springs?</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/spec-for-mmu2-springs/#post-175566</link>
                        <pubDate>Sun, 24 Nov 2019 00:39:58 +0000</pubDate>
                        <description><![CDATA[What are the specs for the springs? They tend (for me) to pop off the screws when opening the MMU2 to clear filament, and I&#039;ve managed to lose one. I know I could get Prusa to send me one, b...]]></description>
                        <content:encoded><![CDATA[<p>What are the specs for the springs? They tend (for me) to pop off the screws when opening the MMU2 to clear filament, and I've managed to lose one. I know I could get Prusa to send me one, but it seems overkill to ship a tiny spring internationally. Researching springs, they don't seem to come in standard sizes, but is there some way to locally source a spring for the MMU2?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Laird Popkin</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/spec-for-mmu2-springs/#post-175566</guid>
