Single Print Purge Tower with SpoolJoin?
Obsessed
(@obsessed)
Hello,
I'm trying to use SpoolJoin, and the issue I keep running into is the new filament is loaded wherever the extruder was when it sensed that it was out of filament on the first spool.  This invariably causes a huge defect in the print if I'm not standing there to catch it switching over.  I've read that it is supposed to purge in the corner, which would be helpful, but even better would be creating a purge tower that could be used to ensure the transition is clean.
Is it possible to trick the machine to do this? Is there some other way to accomplish what I'm looking for? Seems like a pretty simple fix but maybe there is some reason this cannot be implemented.
Napsal : 21/02/2022 12:43 pm
