Selector Motor Ramming into Right
Selector motor usually bumps into the right side once or twice before it decides, 'Ok. This is the end. I know where I am now' and move to the far left before getting to the correct filament but now, it just wants to ram itself to right hand side non-stop.
I re-flashed the firmware into MMU2s board as it solved the same issue in the past but even after flashing both MMU2s and main board with latest firmware, the problem persists. I turned printer off and re-did the wiring to make sure a) nothing is loose 2) everything is wired correctly but t's still very happy to just ram itself into right hand side non-stop.
Does anyone have any suggestions on what I can try next?
Veröffentlicht : 19/05/2022 5:23 pm
