PrusaSlicer creates G-code with wrong nozzle temperature target
thomlop
(@thomlop)
I am using PrusaSlicer 2.1.1+ and trying to print a file using Prusa PLA.  The target temperature in Slicer is 215 degrees for the nozzle but when I load the file in the printer and try to print, the target temperature is 170 degrees.  How do I correct this?
TL
Opublikowany : 22/03/2020 3:17 pm
RE: PrusaSlicer creates G-code with wrong nozzle temperature target
Just wait. Give it 10 minutes. It's a 2 step warmup procedure to reduce oozing during mesh bed leveling. The warmup will take a few minutes on the first print of the day, but will be faster for subsequent prints.
Opublikowany : 22/03/2020 4:14 pm
fil
 fil
(@fil)
THANK YOU!!  This is a pretty cool feature that I didn't see documented anywhere.  I cancelled multiple prints trying to figure this out.
Opublikowany : 08/01/2022 2:00 am
