problems with the 3.8 firmware version and the mmu2s
saver
(@saver)
hi everyone, i had a few problems with my mk3 + mmu2s when i tried to print using PLA and PVA as a soluble support material;
basically i had a failure almost every time the printer wanted to switch from PVA to PLA and vice versa.
I'm also adding video links and pictures in order to give a better understanding;
after a brief search on the web i came to the concusion that downgrading the firmware version from the 3.8 to the 3.6 would have probably solved the problem, so i gave that a try; now i can print again without problems, but i don't want to print again using PVA as a support until some better version comes out....
X_X
pls hlp wtf
Posted : 03/11/2019 9:54 pm
