MMU2s Suddenly selecting wrong filament
The past two weeks I've been printing a series of 2 color panels for a modular synthesizer I'm building. This has been working fairly well up until Friday. I haven't changed my workflow or any settings in Prusa slicer or on the printer - but suddenly when I'm running prints the printer is selecting the wrong filament.
I'm using Filaments #2 and #3 which are white and black PLA respectively. I have #4 and #5 loaded with PETG which I'm not using on this current project.
In Prusaslicer it correctly shows extruder #2 and #3 being used:
But when I run the print instead of changing to #3 it changes to #4 (and the printer display says it's loading #4 so it's not that it thinks it's loading #3 and getting #4 by mistake somehow.)
I've looked at the gcode but am not familiar with the codes used for filament change and couldn't find specs on them to figure out if this is a slicer issue or a printer issue.
Any ideas what could be causing this?
RE: MMU2s Suddenly selecting wrong filament
I have had several issues with strange MMU2 behavior that were all fixed by disconnecting and reconnecting MMU2 control cables at the main board. You might give this a try.
I'll give the old disconnect/reconnect a try.
For reference I uploaded the current g-code that's giving me issues here:
https://gist.github.com/jhitesma/45f05512be6c8f2d6a126eda6c8cd4bb
It looks like T1/2/3/4 are the commands that should change filament...but even though this print only uses extruders 2 and 3 I only see T1 and T2 commands in the gcode so there seems to be something I'm really not understanding about MMU gcode.
Figured it out! Just watched another attempt more carefully.
After it finished with extruder 2 and goes to do the first filament change it does load filament 3. Then makes 2 passes across the wipe tower - but nothing appears to come out. Then it unloads filament 3 and displays a message saying loading filament #4 and starts to load #4.
Which had me scratching my head why it would do that...until I remembered I have spool join on.
Apparently my #3 filament (black, hatchbox - even though my profile says Prusament I've found I get really good results with hatchbox on the prusament presets.) which is nearing the end of the roll has gone a bit brittle and snapped inside the PTFE between the buffer and the MMU. It wasn't visible because every time I looked the ends were pressed against each other and where it was positioned in the tube.
I only found it because I decided to try reloading #3 and when I did I finally noticed the break.
