MMU2 Firmware update issue
I just updated my MK3S to the 3.13.3 firmware successfully. When that completed I got a message saying that the MMU2's firmware is no longer compatible, and to update to 3.0.2. Now, when I try to flash the MMU2 to 3.0.2, it can't seem to find the device.
I found this thread, which seems to describe similar issues, but the resetting solution that was suggested there didn't work for me: https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/firmware-update-problem-after-mmu3-upgrade/
Lastly, I'm not sure if this is an important detail, but when the first dialog box comes up after I select Update Firmware in Prusa Slicer, the Prusa device I see listed next to the com port is Prusa MK3S with no mention of MMU2. Did I flash the wrong MK3S firmware and now the printer no longer "knows" I have an MMU connected?
Anyone else having this problem or have any suggestions?
RE: MMU2 Firmware update issue
Is this the firmware that you loaded?
No, it was this one:
try the other one.
Ok will do, thanks so much!
Had exactly the same problem. After successfully flashing MK3S+, the firmware for MMU2S could not communicate (find) the Computer USB port and the flash failed. Restarted the MK3S+ and reconnected the computer to the MMU2S and It communicated and flashed just fine.
Thanks. I will try this out when I'm back at my printer tonight!
