MMU2 Feeding wrong filament
the MMU 2 started doing this recently usually i reset it and it behaves but to day it was doing it constantly so i had to physically remove it from the printer and run a single filament
apologies for the flipped image
In short I tell it to select filament #1 and it tries to load the filament in the #2 slot
and if the Gcode tells it to select filament #1 it set up for filament 1 then feeds 2
Any help would be appreciated
This topic was modified 7 years ago by Darksheer
Posted : 18/07/2019 3:19 am
