					                		MMU just blinks red lights - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/mmu-just-blinks-red-lights/</link>
                <lastBuildDate>Sat, 09 May 2026 18:25:21 +0000</lastBuildDate>
                        <title>Re: MMU just blinks red lights</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/mmu-just-blinks-red-lights/#post-125770</link>
                        <pubDate>Thu, 24 Jan 2019 17:40:53 +0000</pubDate>
                        <description><![CDATA[Thanks for all of your comments.  I fiddled with the FINDA and blew all of the holes out, and it is working again.]]></description>
                        <content:encoded><![CDATA[<t>Thanks for all of your comments.  I fiddled with the FINDA and blew all of the holes out, and it is working again.</t>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>jon bondy</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/mmu-just-blinks-red-lights/#post-125770</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/mmu-just-blinks-red-lights/#post-125580</link>
                        <pubDate>Wed, 23 Jan 2019 02:50:18 +0000</pubDate>
                        <description><![CDATA[I 100% agree with the other replies. The FINDA would be the first thing I&#039;d check in you situation.
When I suspect the FINDA, I do the following:
1. Unscrew the bolt that holds the FINDA i...]]></description>
                        <content:encoded><![CDATA[<t>I 100% agree with the other replies. The FINDA would be the first thing I'd check in you situation.<br/>
When I suspect the FINDA, I do the following:<br/>
1. Unscrew the bolt that holds the FINDA in place.<br/>
2. Remove the FINDA probe.<br/>
3. While covering 1/4 of the top hole with a finger, I'll spray air through the front hole. Your finger is there just to prevent the ball from jumping out from the air pressure.<br/>
4. Also, blow air in from the top hole.<br/>
5. Reinstall the FINDA probe by following the instructions for setting the FINDA height.</t>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>eschlenz</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/mmu-just-blinks-red-lights/#post-125580</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/mmu-just-blinks-red-lights/#post-125520</link>
                        <pubDate>Tue, 22 Jan 2019 16:05:57 +0000</pubDate>
                        <description><![CDATA[Moved to appropriate forum.]]></description>
                        <content:encoded><![CDATA[<t>Moved to appropriate forum.</t>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>richard.l</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/mmu-just-blinks-red-lights/#post-125520</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/mmu-just-blinks-red-lights/#post-125465</link>
                        <pubDate>Tue, 22 Jan 2019 01:48:58 +0000</pubDate>
                        <description><![CDATA[maybe your ball is stuck abit. but 100% sounds like finda issue]]></description>
                        <content:encoded><![CDATA[<t>maybe your ball is stuck abit. but 100% sounds like finda issue</t>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>toaf</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/mmu-just-blinks-red-lights/#post-125465</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/mmu-just-blinks-red-lights/#post-125443</link>
                        <pubDate>Mon, 21 Jan 2019 23:48:21 +0000</pubDate>
                        <description><![CDATA[FINDA glowing red light -&gt; no filament
FINDA is dark -&gt; filament detected or FINDA doesn&#039;t get power]]></description>
                        <content:encoded><![CDATA[<t>FINDA glowing red light -&gt; no filament<br/>
FINDA is dark -&gt; filament detected or FINDA doesn't get power</t>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Nikolai</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/mmu-just-blinks-red-lights/#post-125443</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/mmu-just-blinks-red-lights/#post-125440</link>
                        <pubDate>Mon, 21 Jan 2019 22:35:44 +0000</pubDate>
                        <description><![CDATA[Usually means the FINDA is activated, i.e. filament or strings stuck under the steel ball.]]></description>
                        <content:encoded><![CDATA[<t>Usually means the FINDA is activated, i.e. filament or strings stuck under the steel ball.</t>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Olef</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/mmu-just-blinks-red-lights/#post-125440</guid>
                        <title>MMU just blinks red lights</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/mmu-just-blinks-red-lights/#post-125434</link>
                        <pubDate>Mon, 21 Jan 2019 22:00:25 +0000</pubDate>
                        <description><![CDATA[Not sure that this is the right place in the forum for this.
The MMU has worked OK for a few months, but suddenly all of the LEDs blink red immediately after I power up.  There is no filame...]]></description>
                        <content:encoded><![CDATA[<t>Not sure that this is the right place in the forum for this.<br/>
The MMU has worked OK for a few months, but suddenly all of the LEDs blink red immediately after I power up.  There is no filament sticking out to impede the slider from moving back and forth, and the slider moves easily when the power is off and I move the threaded rod.  <br/>
Any suggestions?</t>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/mmu-just-blinks-red-lights/#post-125434</guid>
