Manual filament selection dual color print
Hello,
for a single color print, it is easy to select the desired filament at the printer console.
Is it possible (for a dual color print) to select both colors at the printer console? I would like the have one gcode for all the combinations and select them with each print (in this case, it is a dual color coded connector). E.g. filament 1 and 2 or filament 3 an 5 etc.
Is this possible?
CU
Jens
Opublikowany : 16/09/2021 5:54 am
