Lengthened PTFE from 360 to 510mm; how to change MMU code?
Página 2 / 2
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Lengthened PTFE from 360 to 510mm; how to change MMU code?
Z axis is ?
Sorry, but there's nothing else I can think of 🙁
Maybe you could PM Waldemar: https://shop.prusa3d.com/forum/memberlist.php?mode=viewprofile&u=12252 He regularly compiles the firmware.
Peter
Respondido : 14/12/2018 10:26 am
Kryssie
(@kryssie)
Will do. Thank you for all your help, too. 🙂
Fair farren
Respondido : 14/12/2018 11:52 am
3d-gussner
(@3d-gussner)
Reputable Member Prusa-Translations
1st sorry for the late answer but didn't get any notification that i got a PM.
What i understand is:
1. You have a modified Prusa MK3 with much higher z axis, right?
1.a. You set your #define Z_MAX_POS from 210 to 350 and you cannot xyz- or z-calibrate it and get a "?" on the LCD screen
2. You have a MMU2 and need much longer bowden length due your modified MK3, right?
Here some tips i can give you:
To solve issue 1 / 1.a:
Try https://github.com/3d-gussner/Prusa-Firmware/wiki/How-to:-Build-Prusa-Firmware
and
Find in "Firmware/ultralcd.cpp"
switch (axis) {
case 0: axis_length = X_MAX_POS; break;
case 1: axis_length = Y_MAX_POS + 8; break;
and modify it to
switch (axis) {
case 2: axis_length = Z_MAX_POS; break;
If you have a modified MK3 you should also consider to pull https://github.com/prusa3d/Prusa-Firmware/pull/1263
I used these changes for the Zaribo Firmware https://github.com/Zaribo/Zaribo-Firmware/tree/Zaribo-MK3 https://github.com/Zaribo/Zaribo-Firmware/releases
To solve issue 2:
Don't know how far Prusa MMU2 firmware allows to extend the bowden length.
I see lot of people having great results with the modified MMU2+MK3 firmware from TheZeroBeast https://github.com/TheZeroBeast/MM-control-01/releases
At this moment his Prusa-Firmware branch also missed the case 2: axis_length = Z_MAX_POS; break; part and the pull request i mentioned above.
Hope that helps.
Respondido : 19/12/2018 4:41 am
Kryssie
(@kryssie)
Wow. Thank you! Yeah, I don't get PM notifications either 🙁
I will look through everything you sent and post if I have any questions. Thanks again 🙂
Fair farren
Respondido : 19/12/2018 10:44 am
3d-gussner
(@3d-gussner)
Just hope that solves your issue. If you have any other questions let me know via this post or an issue on my Github. These at least send notifications 🙂
Respondido : 19/12/2018 11:44 am
PJR
 PJR
(@pjr)
Hint: Edit your notification settings in the User Control Panel
Peter
Respondido : 19/12/2018 2:32 pm
3d-gussner
(@3d-gussner)
Peter
Thanks Peter ... found it 🙂
Respondido : 19/12/2018 3:57 pm
Kryssie
(@kryssie)
Ok waldemar.g, you have fixed my problems. Thank you thank you thank you thank you thank you! 😀 It was a conflict in the ultralcd.cpp that was causing the ?, I think.
Wishing you a safe and happy Christmas and new year, forever grateful!
Fairfarren
Fair farren
Respondido : 20/12/2018 5:27 am
3d-gussner
(@3d-gussner)
Fairfarren
Also Merry Christmas and a happy new year.
Glad it worked out for you and I could help.
As said consider the TheZeroBeast firmware as I think Robert did a great job.
Respondido : 20/12/2018 12:12 pm
Kryssie
(@kryssie)
Ok, do you know where I find the MK3 5.0.4 RC4 firmware for the printer? I have the firmware for the MMU, and that works fine, but because it's now not aligned with the printer firmware, the printer responds like a single head MK3 again and no longer has menu options for loading filaments through the MMU system.
I got the MMU firmware 2.1.5 from https://github.com/TheZeroBeast/MM-control-01/releases and there is spoken of the MK3 firmware but nowhere to download the source code.
Fair farren
Respondido : 22/12/2018 3:42 am
3d-gussner
(@3d-gussner)
Hi best is to ask Robert TheZeroBeast that he updates his Prusa-Firmware github repository. Open an issue on github and he will answer very soon.
Respondido : 22/12/2018 5:59 am
Kryssie
(@kryssie)
He answered with a link to https://github.com/TheZeroBeast/Prusa-Firmware which is great, but... When I verify the build, Arduino throws up a whole A4 page of errors. Yay. So back to work 😥
Fair farren
Respondido : 23/12/2018 2:43 am
Página 2 / 2
