Re: Lengthened PTFE from 360 to 510mm; how to change MMU code?
Z axis is ?
Sorry, but there's nothing else I can think of 🙁
Maybe you could PM Waldemar: https://shop.prusa3d.com/forum/memberlist.php?mode=viewprofile&u=12252 He regularly compiles the firmware.
Peter
Will do. Thank you for all your help, too. 🙂
Fair farren
1st sorry for the late answer but didn't get any notification that i got a PM.
What i understand is:
1. You have a modified Prusa MK3 with much higher z axis, right?
1.a. You set your #define Z_MAX_POS from 210 to 350 and you cannot xyz- or z-calibrate it and get a "?" on the LCD screen
2. You have a MMU2 and need much longer bowden length due your modified MK3, right?
Here some tips i can give you:
To solve issue 1 / 1.a:
Try https://github.com/3d-gussner/Prusa-Firmware/wiki/How-to:-Build-Prusa-Firmware
and
Find in "Firmware/ultralcd.cpp"
switch (axis) {
case 0: axis_length = X_MAX_POS; break;
case 1: axis_length = Y_MAX_POS + 8; break;
and modify it to
switch (axis) {
case 2: axis_length = Z_MAX_POS; break;
If you have a modified MK3 you should also consider to pull https://github.com/prusa3d/Prusa-Firmware/pull/1263
I used these changes for the Zaribo Firmware https://github.com/Zaribo/Zaribo-Firmware/tree/Zaribo-MK3 https://github.com/Zaribo/Zaribo-Firmware/releases
To solve issue 2:
Don't know how far Prusa MMU2 firmware allows to extend the bowden length.
I see lot of people having great results with the modified MMU2+MK3 firmware from TheZeroBeast https://github.com/TheZeroBeast/MM-control-01/releases
At this moment his Prusa-Firmware branch also missed the case 2: axis_length = Z_MAX_POS; break;
part and the pull request i mentioned above.
Hope that helps.
Wow. Thank you! Yeah, I don't get PM notifications either 🙁
I will look through everything you sent and post if I have any questions. Thanks again 🙂
Fair farren
Just hope that solves your issue. If you have any other questions let me know via this post or an issue on my Github. These at least send notifications 🙂
Hint: Edit your notification settings in the User Control Panel
Peter
Peter
Thanks Peter ... found it 🙂
Ok waldemar.g, you have fixed my problems. Thank you thank you thank you thank you thank you! 😀 It was a conflict in the ultralcd.cpp that was causing the ?, I think.
Wishing you a safe and happy Christmas and new year, forever grateful!
Fairfarren
Fair farren
Fairfarren
Also Merry Christmas and a happy new year.
Glad it worked out for you and I could help.
As said consider the TheZeroBeast firmware as I think Robert did a great job.
Ok, do you know where I find the MK3 5.0.4 RC4 firmware for the printer? I have the firmware for the MMU, and that works fine, but because it's now not aligned with the printer firmware, the printer responds like a single head MK3 again and no longer has menu options for loading filaments through the MMU system.
I got the MMU firmware 2.1.5 from https://github.com/TheZeroBeast/MM-control-01/releases and there is spoken of the MK3 firmware but nowhere to download the source code.
Fair farren
Hi best is to ask Robert TheZeroBeast that he updates his Prusa-Firmware github repository. Open an issue on github and he will answer very soon.
He answered with a link to https://github.com/TheZeroBeast/Prusa-Firmware which is great, but... When I verify the build, Arduino throws up a whole A4 page of errors. Yay. So back to work 😥
Fair farren
