LCD display ->boxes almost everywhere
TheNick
(@thenick)
Hi guys,
I have a problem with the LCD display since this morning - it shows almost everywhere boxes (see the picture). Any suggestions?
Regards,
Nikola
Posted : 09/11/2018 9:08 am
TheNick
(@thenick)
Re: LCD display ->boxes almost everywhere
Forgot to mention that the printer is i3 MK3 with MMU2.0.
Posted : 09/11/2018 9:14 am
AbeFM
(@abefm)
Wiggle the cables on the back of the card. I think I had some bad solder joints on my display, my SD card would unmount sometimes or the machine would reset.
That's likely bad serial communications, so I would try reseating the connectors and see if it helps.
Also, if you recently flashed the firmware, maybe you messed up something. 🙂
I maintain an informal list of San Diego, CA 3D printing enthusiasts. PM me for details. If you include a contact email and I can add you to the informal mailing list.
Posted : 14/11/2018 6:18 am
TheNick
(@thenick)
That's likely bad serial communications, so I would try reseating the connectors and see if it helps. - it doesn`t help
Also, if you recently flashed the firmware, maybe you messed up something. 🙂 - I flashed the firmware after the problem appeared
Posted : 14/11/2018 10:12 am
