How to transfer user-saved filament presets from "MK3S & MK3S+" to MMU2S?
derei
(@derei)
Background:
I have several filament presets fine-tuned, which I used on the printer without the MMU2.
Issue:
I want to be able to use the same filaments in the MMU2S configuration, but apparently there is no way to transfer filament presets between printer configs.
I believe the problem stems in the Filament Import interface, where the available filaments for MMU2 config are fewer compared to MMU2S-Single and MK3S/+
  https://github.com/prusa3d/PrusaSlicer/issues/14928
Desired outcome:
As the filament printing specs didn't change (same filament, same temperatures, etc), I would like to be able to use them on the same printer, but this time through the MMU2S.
Any workaround?
Ce sujet a été modifié il y a 1 day par derei
Publié : 20/10/2025 11:50 am
