Cannot flash the brandnew MMU2S to 1.06 "Flashing failed: Error: open: Zugriff verweigert
Maybe some of you guys can help on this problem:
- updated the MK3S to the 3.8.0 without any problems
- updating the MMU2s (is now on 1.0.5) fails with this print:
I´d already gave a try with:
- previous slicer version
- different USB-cables (incl. checking the windows USB-driver, which seem to be correct)
- different computer (both in admin mode)
- factory reset
The communication between MK3S and MMU2S seem to work (at least filament is loading sometimes and if loaded, it prints)
Kind regards
Alex
RE: Cannot flash the brandnew MMU2S to 1.06 "Flashing failed: Error: open: Zugriff verweigert
Hi Alex,
just before you try to reflash, try pressing the reset button on the side of the mmu2, next to the usb port
Hi Joan,
thanks a lot for your reply - unfortunately, this does also not help.
I´ve tried various timings for the reset, but there is always the same reaction.
Maybe, I´ve just got a defective board...
Best regards
Alex
have you been able to have a chat with support?
Joan
Hi Joan,
yes, finally I decided to ask the PRUSA support - and as always superb reaction, but still under investigation 🙂
Best regards
Alex
Best wishes for a timely resolution!...
by the way, do you have a different micro USB cable that you could try?
and did you have the printer usb cable disconnected whilst you tried to program the MMU?
