Adjusting temperature to avoid irregular end
david.r71
(@david-r71)
I have problems with the tip shape after unload. In the manual says that you need to adjust the temperature with no more explanation. I already change the number of cooling moves to 3.
What temperature should I set? I´m using PLA.
Posted : 24/01/2019 9:49 pm
Nikolai
(@nikolai)
Re: Adjusting temperature to avoid irregular end
Print a temp tower and try to set as low as possible first. If that works, you can then start to increase by 5C.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Posted : 24/01/2019 10:17 pm
