Wipe tower size
I found this quite odd. I printed a two color printed object with 3 instances and customized the purge volume to eliminate bleeding between the colors. After that print completed, I decided to change the number of instances from 3 to 6. I didn't notice until half way thru this print that the purge tower was larger even though the purge volumes did not change. The amount of purging shouldn't change for an increased number of printing the same object, in my mind. Can someone explain why this occurs?
Ce sujet a été modifié il y a 3 years par Geekware
Publié : 27/10/2022 5:47 pm
RE: Wipe tower size
Good question. Why is that?
Publié : 28/01/2023 11:13 pm
