Week 3
Pagina 1 / 2
stephen.c14
(@stephen-c14)
Week 3
We are three weeks into this release and I am amazed on the low volume of finished prints being displayed here. Am I wrong?
Steve
Postato : 26/09/2018 10:33 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Week 3
http://www.kisslicertalk.com/viewtopic.php?f=15&t=2371&sid=2568829b31643dc1320d35434035d150
Peter
Postato : 26/09/2018 11:11 am
Re: Week 3
That British Shorthair print is most impressive Peter!
Postato : 26/09/2018 11:16 am
PJR
 PJR
(@pjr)
Re: Week 3
Thanks - it's actually a money box, with the coin slot at the back of the collar. We have a British Shorthair with similar colouration 🙂 It's a "paid-for" model by Loubie.
Peter
Postato : 26/09/2018 11:34 am
Paul Meyer
(@paul-meyer)
Re: Week 3
Steve
I've had mine running for a week and do not yet have a successful print (focusing just on the 50% sized sheep, two filament).
Postato : 26/09/2018 6:52 pm
stephen.c14
(@stephen-c14)
Re: Week 3
Those are some good prints, but is that from one person that has had it longer than three weeks? Where are the big number of prints from the first owners of the shipped product?
Steve
Postato : 27/09/2018 10:26 am
PJR
 PJR
(@pjr)
Re: Week 3
Steve
Absolutely correct, but if you look there are more photos almost every day 🙂
And yes, I totally agree that there is a complete lack of users posting anything about it 🙁
Peter
Postato : 27/09/2018 10:56 am
Daniel
(@daniel-19)
Re: Week 3
I have the mmu since about 2,5 weeks now and would like to share some prints but as there are still too much problems with load / unload I cannot run any print successfully (keyword missing layers).
There are others with similar issues so probably there are a lot of units not in use at the moment (like mine) or they are still trying to figure out the issue until prusa provide a newer firmware.
Postato : 27/09/2018 5:46 pm
nuroo
(@nuroo)
Re: Week 3
Same here. My MMU2 is sitting idle. I'm afraid to try an ambitious multicolor print for fear of a layer skip the mk3 won't catch, wasting a bunch of filament on the process.
Looking at that clown fish makes sad. I was so close too. During the missing white layer, mk3 was just printing air.
So now all I've done in the past few days is try and tweak ramming settings to work with my various filaments. That and check GitHub every 6 hours for a new firmware.
Prusa MK3 > MK4s
Prusa MK2.5 kit > MK3 > MK3s > MK4s
Prusa SL1 3D printer + Curing and Washing Machine (day1 order)
Taz6 - taken apart for space
CR10s4 - upgrading
Delta 3ku - dont use
Postato : 27/09/2018 6:34 pm
Daniel
(@daniel-19)
Re: Week 3
Yes and no word from prusa about that.
Contacted live chat - they told me I should contact them threw mail
Contacted them threw mail - they was not really helpful and I told them that I created a github ticket, after that they just said that they will look into it and I can keep on testing
I have seen lots of guys with the same issue and I checked all my mechanical things several times but I think the issue comes from the firmware (missing extruder sensor, wrong ramming settings and temperatures for prusa filament, etc)
Postato : 27/09/2018 8:57 pm
Peter L
(@peter-l)
Re: Week 3
One thing you can do while waiting is measure the diameter of your five gears and rearrange them so the smallest gear is on filament 1.
That's not optimal, but may get you going while waiting for a firmware update that lets you calibrate each gear individually.
Postato : 27/09/2018 9:21 pm
Daniel
(@daniel-19)
Re: Week 3
Checked mine today and all are withing +-0.02mm (as good as I can measure them)
Postato : 27/09/2018 9:53 pm
nuroo
(@nuroo)
Re: Week 3
New pre release v3.4.1-RC1
https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.4.1-RC1
Nothing for mmu2 🙁
Prusa MK3 > MK4s
CR10s4 - upgrading
Postato : 28/09/2018 1:02 am
Daniel
(@daniel-19)
Re: Week 3
Yes completely nothing...
Really frustrating, we probably will not get our units working for a while.
Postato : 28/09/2018 10:11 am
PJR
 PJR
(@pjr)
Re: Week 3
There may be another temporary work-around:
Can you try setting the "Loading speed at start" value to 19 mm/s for all filament, slice a small model and try that. Things should improve slightly. You could also try setting the "Loading speed" to 22 mm/sec for all filaments.
This is an attempt to match the Bondtech speed with the MMU.
Peter
Postato : 28/09/2018 12:00 pm
PJR
 PJR
(@pjr)
Re: Week 3
There's also a couple of other things you can try:
Printer Start G-code - reduce E acceleration to 1000:
M201 E1000
And set the "Unloading speed at the start" (see image on previous post) to 80 mm/s for each filament.
I also play around with the E micro-stepping, setting to 1/8 for ramming and unload then back to 1/32, and E motor currents, setting to 24 for print, 31 for unload and 0 during tool change, with holding currents to 16 and 0 during tool change. However, I would not recommend you consider doing this, unless you really know what you are doing.
Peter
Postato : 28/09/2018 12:07 pm
Ojrik
(@ojrik)
Re: Week 3
Postato : 28/09/2018 12:31 pm
Ojrik
(@ojrik)
Re: Week 3
So this is my MMU
from mmu v2 board schematic folded.
v2
Postato : 28/09/2018 12:40 pm
Ojrik
(@ojrik)
Re: Week 3
Postato : 28/09/2018 12:51 pm
ray.a
(@ray-a)
Re: Week 3
I have mine assembled as of yesterday but haven't tried using it for a few reasons...
1) Not enough time yet
2) I need to come up with a better spool mounting solution for spools in an enclosure with desiccant. Without one, MMU is a non-starter. My garage is far too humid, it turns filament to junk within a week or less.
3) Frankly I'd rather wait a few more weeks and let other people deal with early adopter software/firmware issues. See #1.
Postato : 28/09/2018 4:24 pm
Pagina 1 / 2
