Simplify 3D with MMU2 single extruder mode
josh.w3
(@josh-w3)
Searched around on this, but only came up with references to the original PRUSA MMU. Has anyone seen mention of using Simply 3D with the new MMU 2.0 in single extruder mode? I have some single material models that really print best with the supports that S3D generates, however the gcode that comes out of S3D as-is does not have the instructions to navigate the MMU2 filament pre-load sequence. Seems like it's probably as simple as copying a portion of the startup script and ending script from Slic3r to S3D, but wanted to see if someone else was working on this before I started experimenting.
Thanks.
Veröffentlicht : 25/09/2018 4:47 pm
Bstark
(@bstark)
Re: Simplify 3D with MMU2 single extruder mode
I asked Simplified 3d and sent me this profile, but they said it hasn't been tested and you will need to adjust the retraction.
Veröffentlicht : 10/11/2018 8:42 am
