MMU 2.0 -> water soluble support
TheNick
(@thenick)
Hi guys,
I am using Prusa i3 MK3 with MMU 2.0 and Slic3r v1.41.0. I want to try the water soluble support materials, but I cannot see this option anywhere?
Posted : 08/11/2018 9:42 am
maxx78
(@maxx78)
Re: MMU 2.0 -> water soluble support
you need to select the "normal" MMU Printer. Now you have selected MMU single mode
Posted : 08/11/2018 10:25 am
TheNick
(@thenick)
Even I change the tab next to printer to Original Prusa i3 MK3 MMU2, I still have just two options under printer settings :
- 0.15mm OPTIMAL MK3
-0.2mm FAST MK3
Posted : 08/11/2018 10:29 am
maxx78
(@maxx78)
ah, ok.
try under the tab Print Settings- >Multiple Extruders. There are some settings which extruder to use for support
Posted : 08/11/2018 10:34 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Under the "Print Settings" tab, you need to select
0.20mm FAST MK3 SOLUBLE INTERFACE
or the 0.15mm "Optimal" version
And your soluble filament should be in position E5
Peter
Posted : 08/11/2018 1:41 pm
TheNick
(@thenick)
Peter
Thank you Peter, but exactly this is the problem - I don`t have 0.15/ 0.2 0.20mm FAST MK3 SOLUBLE INTERFACE...
Posted : 08/11/2018 1:57 pm
Peter L
(@peter-l)
The soluble interface profiles were just released in the last week or so. Make sure you've updated to the latest profiles.
Posted : 08/11/2018 2:53 pm
