Comparing MMU2 and Palette+
Pagina 5 / 6
joreal
(@joreal)
Re: Comparing MMU2 and Palette+
Chroma+SlicerPE (left), Slic3rPE+P2PP(right)
Postato : 16/01/2019 4:13 am
joreal
(@joreal)
With this P2PP plug-in, purge block size is no longer issue when comparing Prusa MMU2.0 and Mosaic Palette 2.
Postato : 16/01/2019 4:17 am
toaf
 toaf
(@toaf)
was that huge purge block around 1/6th the build plate? good gods.
Postato : 16/01/2019 4:18 am
joreal
(@joreal)
Yes. And heavy. I was not able to compare the weight last night(Asia) because I ran of 9V battery for my weighing scale.
Can cause skull facture if thrown to someone’s head. Might be keeping it for self defence. Hahaha.
Postato : 16/01/2019 5:42 am
toaf
 toaf
(@toaf)
size wise alone. took up allot of the bed.
my 3200 tool change purge block was 1.4 pounds
Postato : 16/01/2019 6:08 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Just one of the reasons why I don't use Slic3r 😉
Peter
Postato : 16/01/2019 10:17 am
joreal
(@joreal)
Peter
What slicer are yiu using?
Postato : 16/01/2019 1:14 pm
toaf
 toaf
(@toaf)
Peter
he is our kiss expert
Postato : 16/01/2019 1:25 pm
toaf
 toaf
(@toaf)
Peter
it was for my tool change test, i could have made it smaller by abit, but it wouldn't have been too much smaller. i would not blame slicer for this huge purge block. i will give them that one.
Postato : 16/01/2019 1:33 pm
PJR
 PJR
(@pjr)
Ex = something that has been
Spurt = drip under pressure.
It's not nice calling someone a "has-been drip under pressure" 😉
But thanks, anyways 🙂
Peter
Postato : 16/01/2019 4:20 pm
Nikolai
(@nikolai)
Noooo. Peter is our KISS emissary. 😉
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Postato : 16/01/2019 6:42 pm
joreal
(@joreal)
I'm enjoying using Palette 2.0 making my MMU2.0 idle for almost 2 months now. And now that I'm using P2PP post processing plugin there is no reason for me to revert back to MMU2.0, probably except if I need 5 materials.
Postato : 23/01/2019 7:16 am
toaf
 toaf
(@toaf)
hey does palette let you "pre splice" filament? I might want to run a funky test 😀
Postato : 23/01/2019 7:48 am
Peter L
(@peter-l)
Not sure about the Palette 2, but the Palette+ has a test mode where it will just splice a bunch of segments together in different colors. You can use it to replace plain filament and get a horizontal stripe look.
Postato : 23/01/2019 4:49 pm
digibluh
(@digibluh)
yes.
Postato : 24/01/2019 1:18 am
Super7
(@super7)
Hi all
I’m thinking of buying a Palette 2 pro or Prusa MMU but was wondering about the following...
Some of the things I make have a cutout ‘text’ on the bottom few layers. I would like to have these ‘coloured’ in. This text would be no more than say 2mm thick, how much extra time would this take to print, they currently take roughly 2 hours. Also, how big would the purge block be?
Am I right in thinking that as it would only be 10 layers (at 0.2mm / layer) it wouldn’t add much to the print time or create a big purge block?
Apologies if this is a stupid question, I’m quite new to this!
Postato : 03/02/2019 11:30 am
I use this technique
Minimal waste
If background is dark. You need opaque colours to prevent dull infill
I recently put a white patch behind red infill on black background because the red was not opaque enough
Joan
Postato : 03/02/2019 2:15 pm
toaf
 toaf
(@toaf)
Hi all
it adds roughly 90 seconds per color change.
Postato : 03/02/2019 5:31 pm
Super7
(@super7)
Thanks, that’s not bad at all.
Looks like I’ll be going with the Palette 2, as the Prusa mmu still has a 2 month backlog.
Postato : 03/02/2019 7:03 pm
Peter L
(@peter-l)
It's going to depend somewhat on your settings, but a ballpark estimate is that the MMU2 adds 60-90 seconds per filament change, and the Palette2 adds about half that (30-45 seconds) per filament change.
Once you get your purge settings tuned, the MMU2 will consume on average around 0.5g of purge per change, and the Palette2 will consume around double that (~1g) per change.
Adding some color to the top or bottom layers of a print is pretty close to the ideal situation for minimizing tool changes. I've found that often I only need to color 0.5mm (2-3 layers, depending on settings) to get the effect I want. You can do a surprising amount with less than a dozen tool changes...
Postato : 05/02/2019 3:51 pm
Pagina 5 / 6
