Is there an inventory of all the parts used in the MMU2S?
luvology
(@luvology)
I might take up he courage of putting up the mmu2s by myself. Plan to buy the parts from Pursa Store.
Is there an inventory of all the parts i would need for building the MMU2S?
Posted : 19/05/2020 6:22 pm
RE: Is there an inventory of all the parts used in the MMU2S?
check out the MMU2S assembly guide, all of the parts are itemised there.
the AliExpress adverts say
M2x8 screw*1
M3x6 screw * 38
M3x10 screw * 16
M3x12 screw * 5
M3x14 screw * 13
M3x18 screw * 6
M3x20 screw * 4
M3x30 screw * 16
M3x40 screw * 5
M3n nut * 35
M3nS nut * 36
Shaft 5x16sh * 8
Spring 0.8X5X15mm * 3
608zz bearing*20
625zz bearing * 9
Blade*2
Shaft 8X120sh*10
2.MM control board*1+power cable*1+signal cable*1
3.motors kit-39mm stepper motor*1+110mm length rod motor*1+120MM motor*1
4.120mm smooth rods*2+ brass tube 5x6x25bt*2
5.extruder gears*5
6.PTFE Tube Teflonto 1.9*4*4m+pneumatic fittings*2(gift:ptfe cutter)
7.IR Sensor*1+P.I.N.A. ball*1
8.spool holders *5
9.filament buffer *6
Posted : 19/05/2020 9:26 pm
Posted by: @luvology
This is my modified MMU2 (partslist without screws, nuts and springs): https://grabcad.com/library/mmu2-mmu2s-multi-material-unit-v2-3-1
Joan has already listed the screws and nuts.
Posted : 19/05/2020 10:16 pm
