Cant find MMU v2 stl's
nuroo
(@nuroo)
Received my MMU2 kit. Upgraded my MK3 to R3 extruder. So of course I applied to much torque while screwing the Idler bearings assembly to the motor shaft and cracked the plastic printed part...... need to reprint it.
I looked here:
https://www.prusa3d.com/prusa-i3-printable-parts/
Following this guide:
https://manual.prusa3d.com/Guide/1.+Idler+body+assembly/756
which also references the first link. But I dont see the v2 MMU parts??
Prusa MK3 > MK4s
Prusa MK2.5 kit > MK3 > MK3s > MK4s
Prusa SL1 3D printer + Curing and Washing Machine (day1 order)
Taz6 - taken apart for space
CR10s4 - upgrading
Delta 3ku - dont use
Posted : 05/09/2018 10:08 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Cant find MMU v2 stl's
MMU2 parts are here: https://github.com/prusa3d/Original-Prusa-i3/tree/MMU2
Peter
Posted : 05/09/2018 10:13 pm
nuroo
(@nuroo)
Thank you.....
Prusa MK3 > MK4s
CR10s4 - upgrading
Posted : 05/09/2018 10:21 pm
nuroo
(@nuroo)
Hard for end users to load into slicer....
A. if i click on any of the stl's, there is option to download. If i click download button it simply list contents of stl file, but doesn't offer download of file.
B. if i right click the stl. file and choose "save as" the file will download > however this file cant be loaded into slic3r, gives error.
I had cut and paste the contents from A, into a blank note pad++ file and save it. Then slic3r loads the stl.
Prusa MK3 > MK4s
CR10s4 - upgrading
Posted : 06/09/2018 12:45 am
PJR
 PJR
(@pjr)
Go to the link I gave you; there is a green "Clone or Download" button. Press that and you will be able to download all as a zip file.
Peter
Posted : 06/09/2018 9:17 am
nuroo
(@nuroo)
Thanks for the help..... If I down loaded the whole zip > the button your referring too.... no issues
I tried to download only the stl's i needed, ran into problems.
Prusa MK3 > MK4s
CR10s4 - upgrading
Posted : 07/09/2018 4:09 am
Jorg
 Jorg
(@jorg)
Are the filament guides for the spool holders available somewhere?
Posted : 08/09/2018 8:14 pm
nuroo
(@nuroo)
Yes they are in the zip files linked above by PJR
Prusa MK3 > MK4s
CR10s4 - upgrading
Posted : 08/09/2018 9:21 pm
Jorg
 Jorg
(@jorg)
I looked in that one... It has 10 files, but they are all components for the MMU, I was hoping to find the components listed in step 7 in
https://manual.prusa3d.com/Guide/4.+Spool+holder+assembly/758?lang=en
Well, it has the end stops (file: mmu2-s-holder-endstop), but I could not find the others...
Posted : 08/09/2018 9:43 pm
nuroo
(@nuroo)
They are in the zip file
stl's > all files including step 7:
mmu2-s-holder-base (1x)
mmu2-s-holder-lever-a (1x)
mmu2-s-holder-lever-b (1x)
Prusa MK3 > MK4s
CR10s4 - upgrading
Posted : 08/09/2018 10:27 pm
Jorg
 Jorg
(@jorg)
Oh... I downloaded the SCAD files, but for those there are only the STL files... 🙄
I had hoped for the SCAD files or so, to better look at the design, but at least it is something. 🙂
Thanks!
Posted : 08/09/2018 11:01 pm
Tveito
(@tveito-2)
The fillament guide is in the step folder (use something like fusion 360 to alter them)
Posted : 01/10/2018 8:21 pm
