2nd Filament fails to reach extruder after bowden length calibration
Seite 1 / 5
yan liang.t
(@yan-liang-t)
After carrying out the bowden length calibration (by default it does it on the 1st failment), the printer manages to load the 1st filament into the extruder (with the extruder catching) for the lizard print.
However, I realised that the MMU is unable to load the 2nd filament into the extruder using the sheep print, which uses the 2nd filament first. After unscrewing the PTFE tube to the extruder, the filament length seems not long enough to reach the extruder gears for them to catch, hence the problem.
I have been scratching my head around this problem, since the second filament should have been loaded the same length as the first, and the first was successful in loading into the extruder. Any ideas? 😐
Veröffentlicht : 25/09/2018 7:51 am
Re: 2nd Filament fails to reach extruder after bowden length calibration
Hi Yan Ling, check the diameter of the hobbed section of all five MMUv2 drive wheels, they may be different if filament 1 drive wheel is bigger than filament 2 drive wheel, you may have found your problem. if there are differences, re assemble your MMU with the smallest diameter drive wheel in position for filament one... with the larger drive wheels in the remaining 4 filament positions
then re do the calibration on filament 1 and the remaining filaments should feed slightly further, which should be resolved on the purge area
Veröffentlicht : 25/09/2018 8:41 am
yan liang.t
(@yan-liang-t)
Thanks Joan!
Just a clarification - would the drive wheels you are referring to be the big smooth ones that are held by individual shafts, or the toothed ones held by a long central shaft?
Veröffentlicht : 25/09/2018 10:10 am
bozzo
(@bozzo)
Joan, thank you!
Your diagnosis was spot on, I have exactly the same problem as Yan Liang, and had the bad luck of installing one of the largest gears on position 1.
my gears measure 6.25, 5.89, 6.11, 6.26, 6.27 . which at 360mm travel to the extruder tube makes for a difference of 21mm (!) .
Does the system support per-gear calibration? I worry that such a big discrepancy will grind the filament if I calibrate for the smallest gear...
Need to ask support what are the tolerances for the gears...
Veröffentlicht : 25/09/2018 10:20 am
Good morning Bozo, I am pleased that this information helped.
Yan Ling,
I am talking about the drive wheels on the motor shaft
measure at the hobbed cut away point, and sort smallest diameter to largest diameter, then install with the smallest diameter in filament one, position, so that when you configure the feed distance on filament one, it will feed the correct distance, m and other filaments may feed more...mm the excess will be purged into the waste areas.
Veröffentlicht : 25/09/2018 10:55 am
bozzo
(@bozzo)
Talked to the support, really nice chaps. My hobbed gears are out of spec, I'll be getting a new set.
The nominal diameter for the gears is about 6.2.
I'll try installing the three 'good' ones in positions 1, 2, 3 for now to have at least a PMMU (P for partial) 😛
I also created https://github.com/prusa3d/Prusa-Firmware/issues/1194 with an idea how to automate the calibration.
Veröffentlicht : 25/09/2018 11:13 am
I put a note on that paragraph in the online build manual suggesting folk measure and sort the hobbed wheels putting the smallest one on filament one!,
Veröffentlicht : 25/09/2018 12:47 pm
yan liang.t
(@yan-liang-t)
Thanks Joan! Print seems to work fine now on 1st and 2nd filament after swapping. It also makes sense now that my 1st and 2nd wheel has a 0.4 mm diameter difference! 😯
My wheel diameters:
1: 6.30mm
2: 5.92mm
3: 6.27mm
4: 6.15mm
5: 6.25mm
Bozo - Does it mean I should approach support as well?
Veröffentlicht : 25/09/2018 3:47 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
If you can wait a few days, then there should be new firmware available which will allow you to calibrate each filament feed.
Peter
Veröffentlicht : 25/09/2018 4:07 pm
toaf
 toaf
(@toaf)
that should be a good change
Veröffentlicht : 25/09/2018 8:55 pm
TraserParker
(@traserparker)
Oh my word, I just found this... thankful that I’m not the only one with this issue. J spent the last 3 days checking everything and changing the placement of the spools.
@pjr do you know when the fix will be out? Is there an issue on github already for tracking?
Also if I were to do it the mechanical way, would that mean taking the whole MMU apart?
Veröffentlicht : 26/09/2018 9:49 am
toaf
 toaf
(@toaf)
think it's just getting the gears out, measuring them, putting them back smallest to biggest. that might be the whole thing just to get to them, not sure I don't have mine yet 🙁
kinda looks like, if you can get to the screws holding the gear motor your home free
Veröffentlicht : 26/09/2018 10:10 am
bozzo
(@bozzo)
It's quite easy to do, actually, you don't even have to take it off the printer.
[*] remove all filament from the mmu2
[*] cut more or less all the zipties on the mmu (you can keep the one on selector motor), unplug the gear feed motor, the safety latch is on the 'inside' so you'll probably need to unscrew the electronics
[*] unscrew the idler tensioner and open the idler
[*] unscrew all 4 bolts of the feed motor and pull the motor out
[*] shuffle pulleys and reverse the steps 🙂
The second time (sigh) went pretty fast. 🙂
Veröffentlicht : 26/09/2018 10:39 am
PJR
 PJR
(@pjr)
All I know is that it was requested back end of last week. But there is also some other stuff to be done at the same time and there's testing. I would hope this will be resolved soon.
Swapping the pulleys is not a great work-around; you end up pushing the filament into the Bondtech which caould cause skipping at the MMU and result in filament damage - which could lead to skipped layers later in the print 🙁
Peter
Veröffentlicht : 26/09/2018 10:41 am
bozzo
(@bozzo)
Would it create a lot of process/communication overhead if such requests would get recorded as an issue in the public repo. That would make such issues more easily discoverable...
It's far from perfect. There is indeed some grinding going on, but I have already two sucessfull prints under my belt (gecko and sheep) whereas before the swap I could not get any color change to work (due to bad luck of randomly selecting the biggest pulley for no.1)
The gecko was flawless. the sheep I had exactly one retract issue (filament jammed when mmu was pulling it out, luckily it was the last retract at the end of print, I still need to learn how to resolve those)
Veröffentlicht : 26/09/2018 11:21 am
AbeFM
(@abefm)
Mitglied
Peter
I picked the gear just smaller than average, so that I wouldn't ram TOO much, but still get most of them there. With ~40cm in the bowden tube, you can figure out how short you'll be, I'm something like 1 cm now, I was 2.5. I could get it lower but I'd start ramming 4 cm extra into the machine.
I maintain an informal list of San Diego, CA 3D printing enthusiasts. PM me for details. If you include a contact email and I can add you to the informal mailing list.
Veröffentlicht : 26/09/2018 11:40 am
PJR
 PJR
(@pjr)
This is something that is being worked on in-house and in conjunction with beta-testing, but if you wish you can raise an issue on Github.
It's far from perfect. There is indeed some grinding going on...
And that's why I suggested moving the pulleys around - it's simply a temporary work-around; I could have released my fix for the problem, but then I would have become "responsible" for the problems we are experiencing. I would much rather wait for the official solution.
Peter
Veröffentlicht : 26/09/2018 11:43 am
PJR
 PJR
(@pjr)
Yeah, that should be OK. The MMU currently feeds 20mm with the Bondtechs turning at the same time, but the problem is the speed matching when the filament is late arriving. (actually, speed-matching is currently an issue at the moment anyways 🙁 )
Peter
Veröffentlicht : 26/09/2018 11:46 am
Fnord Prefect
(@fnord-prefect)
Ah, I'm glad I found this - this might be exactly the problem I'm having right now. I'll check the calibration and the hobbed wheels when I get home. Thank you!
And, this might be a dumb question, but...
Why is there a need for a bowden length calibration when we have a filament sensor in the extruder?
Veröffentlicht : 26/09/2018 1:28 pm
TraserParker
(@traserparker)
As it is, in its current implementation, I understand that it is not closed loop between the filament sensor and the pulley
Veröffentlicht : 26/09/2018 2:25 pm
Seite 1 / 5
