Z-Axis bearing Holder Upgrade?
The bearing blocks on my Z axis seem to making some buzzing sounds during XY stage movement. When I squeeze them that buzzing seems to go away. I have seen someone that had a bearing block that had screw/nuts on there to compress around the bearing as opposed to just the friction fit that seems to be on the OEM. Does anyone have this file or know what I am talking about?
Mike
Opublikowany : 16/08/2021 7:37 pm
Topic starter
answered:
Bear Upgrade
So these are a part of the Bear upgrade files located here.
https://github.com/gregsaun/bear_extruder_and_x_axis
I'm gonna print off a set and install them. I'll report back with any info once I have tested them.
Opublikowany : 19/08/2021 7:31 pm
File you're looking for
https://www.prusaprinters.org/prints/56241-x-axis-revision-with-belt-tensioner
Opublikowany : 23/08/2021 10:20 am
