Y axis carriage upgrade
Robb
 Robb
(@robb)
I have been having noise issues with the y axis, ever since I built my mk3s a couple months ago.  I have replaced the rods and bearings, adjusted the belt, checked every bolt, I think I have tried everything.  After re-angling the bearings so the balls are perfectly vertical, it worked great for a night, now the side sounds like a dying puppy.  If I remove the belt it glides smooth as butter, but with a tiny bit of force/resistance with the belt, everything goes wrong.  And every time I hear a noise, it always comes from roughly the same place.  It seems to come from the singular bearing on the right side of the carriage.  Depending on how I apply pressure changes the amount of noise, but it's always from the right side.  I believe it is from how easy it is to flex the right side with the fact it isn't balanced with a second bearing, like the left side.
I was thinking of trying this plate out using a fourth bearing on the right side, so it is "perfectly balanced, as all things should be."
https://www.thingiverse.com/thing:3200348
Unless there is one that is prefabbed somewhere that I didn't see, it would probably be a kinda expensive piece to get machined, but I'm out of ideas.
Napsal : 18/10/2019 3:53 am
pingu
(@pingu)
RE: Y axis carriage upgrade
Look on ali express for the seller fystec. There you get exactly this plate wiht housed, screwed down bearings. I ordered last weeg one exactly because of the same issious. It were about 20 dollars.
Napsal : 18/10/2019 4:58 am
