Working (Octopi) Image needed for Rapsberry Pi Zero W // Prusa-Print Image (Prusaprint.zip) CRC failure - File corrupt
Hi all, I want to install a Raspberry Pi Zero W on my MK3S+. I received already my RPB Zero W, and i tried to download the "unsupported" image Prusaprint.zip from the prusa homepage. Any file i try to download fails when I want to open it. there is a CRC error, so the file seems to be corrupt.
Is anyone able to share a working image for the Raspberry Pi Zero W, so that i can try to setup my solution?
Many thanks in advance.
Werner
RE: Working (Octopi) Image needed for Rapsberry Pi Zero W // Prusa-Print Image (Prusaprint.zip) CRC failure - File corrupt
Hi Diem,
thanks for your feedback. I already found the download on the Octoprint homepage, but there they recommend not using a Pi Zero W.
I wanted to get the pre-configured Image from Prusa. They did a image with all the parameters correctly set already. It's called Prusaprint.zip and you can find it on the Prusa Homepage. That's the file or Image which i try to get.
Only problem, the prusaprint.zip file you can download from the prusa homepage seems to be corrupt, as i cant open it with any ZIP, RAR file as it always ends with an CRC error during extraction. Maybe someone can share this file with me?
BR.
Werner
But that version will be massively out of date and wouldn't be recommended to use.
Hi Neophyl,
so you recommend, to make a image from scratch i supose 😉
BR.
Werner
When the Prusa-Print image was created a Pi Zero W was OK for the task but Octoprint has developed dramatically since then and the Zero W is no longer enough. But they do say the Pi Zero 2 W is more than capable.
Installing from scratch is painless.
