Wire Strain Relief for X-Axis Motor MK3S
Gravydog
(@gravydog)
I recently put together a MK3S kit and everything from components and packaging to instructions was first-class but one thing stood out to me. All the wires and so on are well-anchored and restrained except the ones to the X-axis motor which can flex right at the motor. Admittedly there is not a lot of action going on here but still I wanted it to be better.
I looked around for a CAD program to learn and settled on FreeCAD as being suited to my needs for mechanical parts and my way of thinking. I must say it has been surprisingly difficult for me to learn when I have always been very technical, but I am slowly becoming more comfortable with the basics, at least.
Here is the strain relief I designed for my printer:
And here it is printed:
I printed it in ABS and I had to make a setting change in PrusaSlicer to get crisp details in the top few layers because the part is so small. Go to Filament Settings > Cooling and click Enable Auto Cooling. This slows the printing and runs the fan to firm the plastic when it is being overlaid too quickly.
The original attachment:
I had two 3 x 40mm screws left in the spare hardware bag. Attach the part with one of the screws in the right hole as is. The screw for the left hole I shortened to exactly 37.5mm to allow it to seat without colliding with the mounting screw coming from the motor mounting. The strain relief installed:
 I hope someone finds this useful.
Rob
Ce sujet a été modifié il y a 6 years par Gravydog
Publié : 23/12/2019 6:46 pm
Gravydog
(@gravydog)
RE: Wire Strain Relief for X-Axis Motor MK3S
I tried to attach the .stl file, it's not allowed. How can I share my design?
Rob
Publié : 23/12/2019 6:50 pm
Harry
(@harry)
@rrelf51
Hi there
have you already found a solution if not you could send the file to me via mail pls [email protected]
Publié : 25/12/2019 10:46 pm
Harry
(@harry)
@rrelf51
great thank you
Publié : 26/12/2019 7:35 pm
Gravydog
(@gravydog)
I PM'd a mod many days ago asking how I can attach the .stl file, no reply even though he has been active. If there is somewhere that spells out all the rules of the forum I can't find it. Doesn't anyone know the answer to this?
Rob
Publié : 01/01/2020 6:26 pm
@rrelf51
Best practice is to compress the file (*.zip) and then publish it as media data.
wbr, Karl
Publié : 01/01/2020 7:27 pm
anders-1
(@anders-1)
X_AXIS_CABLE_MOUNT_FULL
Publié : 02/01/2020 1:20 pm
anders-1
(@anders-1)
Hello, I thought about exactly the same thing the other day when i got my printer assembled.
The radius on  the hinge is so that you can use the bottom side and a pin to mount a energy chain if that is you preference.(note its not a snap fit so you will need to use the bottom in that case).
Below is the STEP & STL files for the design and i printed it myself in PETG.
X_AX IS_CABLE_MOUNT
Publié : 02/01/2020 1:32 pm
Gravydog
(@gravydog)
Posted by: @karl-herbert
@rrelf51
wbr, Karl
Thanks very much. Here is my design, zipped.
Rob
Attachment removed
Publié : 02/01/2020 6:25 pm
