Which smart features of the MK3s do you lose if you use Octoprint?
ByteSlinger
(@byteslinger)
I have always used Octoprint since I got my Prusa for a number of reasons but recently I've had to switch to printing from SD for a short while.
Prints seem to be coming out nicely and it just got me wondering, which (if any) of the Prusa's smart features do you lose when printing via octoprint?
Postato : 27/01/2021 5:03 pm
RE: Which smart features of the MK3s do you lose if you use Octoprint?
Posted by: @byteslinger
[...] which (if any) of the Prusa's smart features do you lose when printing via octoprint?
A few notes:
  • You lose out on power panic.
  • You're printing via USB instead of from SD card (usually), so there is a dependency on the RPi running OctoPrint being stable, but that's not usually a problem.
  • Some prints with lots of small details can be problematic when printing over USB, but I don't find this an issue in most cases.
  • OctoPrint now includes some plugins (e.g., ArcWelder) that mitigate this.
  • There have been the odd bugs in firmware that can be triggered by OctoPrint & USB printing, but Prusa has been good at fixing those.
All-in-all, I say OctoPrint is a definite net win. The success of power panic is largely dependent on how well your print stays adhered to the bed after cooling, so I don't rely on it.
Postato : 27/01/2021 6:25 pm
1 persone hanno apprezzato
ByteSlinger
(@byteslinger)
@bobstro
So do you still get the benefit of layer shift detection/correction etc when printing via octoprint?
Postato : 27/01/2021 7:05 pm
[...] So do you still get the benefit of layer shift detection/correction etc when printing via octoprint?
So far as I know, crash detection still works. I am not aware of any correction features. All of the thermal runaway protections still work.
Postato : 27/01/2021 7:53 pm
Utenti
@bobstro
Odd bugs?  Say it isn’t so.  I have had some odd errors that make no sense.  They are pretty rare btu annoying if theu happen in 12+ hour of print.
Postato : 27/01/2021 8:50 pm
PRGeno
(@prgeno)
I believe you lose the full functionality of the filament sensor as well
Or at least I haven't figured out how to get Octoprint to stop sending data when the filament runs out or jams.
Postato : 01/02/2021 10:50 pm
androx
(@androx)
@bobstro
Yes the crash detection still work because it is implemented at lower level, but you do not receive any feedback to Octoprint. The message is only about some "user paused".
Postato : 18/04/2021 8:57 am
Baklin
(@baklin)
Posted by: @prgeno
The filament works just fine on the MK3s/+ with octoprint. Just like the crash detection it works but you won't get feedback in octoprint.
I use octoprint to control my printer. When the filament runs out I will here the printer beep in the other room and I will have to check it there and deal with it.
One thing you will lose with octoprint is the use stats, like total filament used and time printed. There is a plug in that works fine for my use called "Printer Stats"
And the counter for fail stats isn't reset when you start a new print. It keep counting from the time the last print was started from sd card.
Postato : 18/04/2021 1:22 pm
towlerg
(@towlerg)
@prgeno
Unless the printer is able to signal filament runout to OctoPrint, streaming will continue. I guess you need to attach the runout sensor to Octoprint.
Postato : 18/04/2021 1:39 pm
Baklin
(@baklin)
Filament sensor works with Octoprint. I haven't changed anything on the Prusa and use a default Octoprint install on a RP3b+.
I just cut the filament on a running print and the Prusa  asks to unload the filament. At the same time Octoprint shows "paused for user" in the terminal.
After changing the filament like you normally would on the Prusa, the print continues and Octoprint returns to normal printing without user interaction.
But this doesn't work for all printers. Depends on the board and sensor connection I think. AFAIK this doesn't work for the Prusa Mini. At least that is what I remember reading here.
Postato : 18/04/2021 3:06 pm
towlerg
(@towlerg)
@baklin
Oh, thats neat, just another reason that I wish I'd bought a Prusa.
I must check out Marlin and see if there's an option I can change.
Postato : 19/04/2021 8:24 am
Utenti
@towlerg
So it stops working?
Postato : 19/04/2021 8:49 am
towlerg
(@towlerg)
@cwbullet
Apparently not, on a MK3? according to post #8 above. Doesn't currently work on my SV01.
Just to be clear are you asking if the runout sensor or the printer/octoprint combo stop working?
Questo post è stato modificato 5 years fa da towlerg
Postato : 19/04/2021 6:09 pm
