Under extrusion after upgrade
Página 2 / 3
RE: Under extrusion after upgrade
Sometimes the theoretical values (400) may differ from the practical (due to manufacturing tolerances) values.
If this fits, you can at least rule out an error.
wbr,
Karl
Respondido : 06/08/2022 5:08 pm
JumpCut me gusta
JumpCut
(@jumpcut)
Yeah, after several tries it is exactly 400. So that is fine. But actual printing is still a no go.
Posted by: @karl-herbert
wbr,
Karl
Respondido : 06/08/2022 7:56 pm
Are you using original PrusaSlicer presets for your filament?
Just to rule out some things:
Are the slicer settings correct?
- Filament diameter
- Nozzle diameter
- Extrusion factor 100% (no M221)
- layerwidth settings
- max volumetric speed
wbr,
Karl
Respondido : 06/08/2022 10:10 pm
JumpCut me gusta
JumpCut
(@jumpcut)
My settings from Prusa slicer:
Filament diameter: 1.75 - (filament settings)
Nozzle diameter: 0,4 mm - (printer settings)
Extrusion factor 100% - (M221 removed from start gcode)
Extrusion layer width 120% - (print settings)
Max volumetric speed 11.5 - (filament settings and print settings)
- Filament diameter
- Nozzle diameter
wbr,
Karl
Respondido : 07/08/2022 5:03 am
JumpCut
(@jumpcut)
I changed to a brand new slice 300 degree termistor, just to be sure. Did a PID-tune after that.
The nozzle I am currently using is a Bondtech CHT 0.4.
Respondido : 07/08/2022 6:33 am
Try printing the 20x20x20mm calibration cube. If you still have problems with under-extrusion, please post the gcode. I would also test your gcode on one of my MK3 printer.
xyzCalibration_cube
wbr,
Karl
Respondido : 07/08/2022 6:43 am
JumpCut me gusta
JumpCut
(@jumpcut)
I tried but I'm not even close. I just end up with a melted ball on the nozzle.
xyzCalibration_cube
wbr,
Karl
Respondido : 07/08/2022 7:02 am
JumpCut
(@jumpcut)
Trying to attach the gcode here but I cant get it to work through the forum.
Respondido : 07/08/2022 7:09 am
JumpCut
(@jumpcut)
https://drive.google.com/file/d/1-N8xh5grZf1YNtzo6zXzUuEiVUnjOCTl/view?usp=sharing
My gcode for the cube.
Respondido : 07/08/2022 7:15 am
JumpCut
(@jumpcut)
I could perhaps also try your cube gcode?
xyzCalibration_cube
wbr,
Karl
Respondido : 07/08/2022 7:16 am
JumpCut
(@jumpcut)
This is what Sainsmart TPU looks like when I try to calibrate.
Respondido : 07/08/2022 7:25 am
JumpCut
(@jumpcut)
Hmm, if I up the flow in the menu during first layer calibration it works better. I tried flow of 400 and then it looks way better but not okay.
Respondido : 07/08/2022 8:27 am
JumpCut
(@jumpcut)
Respondido : 07/08/2022 8:29 am
JumpCut
(@jumpcut)
Hmm, took flow down to 300 and now the first layer calibration looks OK. Very strange. Still can't really print though.
Respondido : 07/08/2022 8:52 am
I briefly checked the gcode (cube not printed) and found an error:
; external perimeters extrusion width = 0.45mm
;perimeters extrusion width = 0.45mm
; infill extrusion width = 0.45mm
; solid infill extrusion width = 0.45mm
; top infill extrusion width = 0.40mm
; first layer extrusion width = 0.24mm
You should replace the last line (first layer extrusion width = 0.24) with a value about 0.42 to 0.45
Give it a try.
wbr,
Karl
Respondido : 07/08/2022 9:36 am
JumpCut me gusta
JumpCut
(@jumpcut)
Trying now!
Give it a try.
wbr,
Karl
Respondido : 07/08/2022 10:17 am
JumpCut
(@jumpcut)
So, I am getting closer.
Right now I am printing the calibration cube. I need to have around 200 flow for it to be able to print.
Respondido : 07/08/2022 10:56 am
JumpCut
(@jumpcut)
After something like 7 layers the cube comes loose from the bed. I'll keep trying with fine tuning of Z, flow and temp.
Esta publicación ha sido modificada el hace 2 years por JumpCut
Respondido : 07/08/2022 11:02 am
JumpCut
(@jumpcut)
After some more fine tuning I'm down to about 120 flow with 1.1 extruder multiplier. So starting to look ok.
Respondido : 07/08/2022 5:42 pm
Would you briefly summarize what were the most important changes that led to the current result?
Thanks!
wbr,
Karl
Respondido : 07/08/2022 7:35 pm
Página 2 / 3
