Stepper Motor Upgrades to Eliminate VFA's (Vertical Fine Artifacts)
Pagina 45 / 54
Bunny Science
(@bunny-science)
RE: Stepper Motor Upgrades to Eliminate VFA's (Vertical Fine Artifacts)
By any chance did you accidentally uncomment, but with a 1.8 degree motor installed?
//#define E_AXIS_MOTOR_09 //kuo exper EXTRUDER
Doing that with a 0.9 degree extruder motor would cause over extrusion. BTW, I don't recommend a 0.9 motor on a geared extruder due to risk of inadequate torque during rapid filament moves.
Postato : 11/02/2020 12:35 pm
Bunny Science
(@bunny-science)
Looking back through the firmware, there are some missing #define EXTRUDER_GEARED.
Please download new copy and see if that helps.
May need to factory reset to get new microsteps to take effect.
Postato : 11/02/2020 12:59 pm
Bunny Science
(@bunny-science)
Should show for 0.9 on xy and 1.8 on E, 3.5 skelestruder
Send: M503
Recv: echo:Steps per unit:
Recv: echo: M92 X100.00 Y100.00 Z400.00 E473.00
Recv: echo:UStep resolution:
Recv: echo: M350 X8 Y8 Z16 E16
Postato : 11/02/2020 1:30 pm
vintagepc
(@vintagepc)
Utenti
BTW, 3.9.0 will have the homing reset bug fixed; there was a corner case that caused a buffer underflow in certain circumstances.
Postato : 11/02/2020 2:02 pm
CybrSage
(@cybrsage)
I wanted to say a big THANK YOU to everyone still making this firmware train stay alive.  You guys are the reason why open source works so well.
It is greatly appreciated.
Postato : 11/02/2020 2:06 pm
1 persone hanno apprezzato
Bunny Science
(@bunny-science)
Grrrr. Word Press kept throwing errors when I was posting earlier. When I angrily pasted for the 5th time, I forgot to edit the e step value
Send: M503
Recv: echo: M92 X100.00 Y100.00 Z400.00 E490.00
Questo post è stato modificato 6 years fa da Bunny Science
Postato : 11/02/2020 3:32 pm
SpecialT
(@specialt)
xD know after i got my 1.8 stepper on the extruder and reuped your config the printer failed every time on XYZ calibration:
always on the z calibration where he moves to the bed and wants to check the 4 points.
calibration starts through the wizard.
Also he doent stops overe the marked location on the heatingbed where the Pinda should be.
The pinda has an offset of 5 mm to the left and 3mm to the front.(viewed from displayside)
//====== Kuo Uncommented def(s) below specify 0.9 degree stepper motors on x, y, z, e axis
//Motors used should be 1 amp or lower current rating to avoid overheating TMC2130 drivers in Stealthchop.
//Kuo recommended 0.9 degree motors for X, Y, or direct drive E are Moons MS17HA2P4100 or OMC 17HM15-0904S
#define X_AXIS_MOTOR_09 //kuo exper X axis
#define Y_AXIS_MOTOR_09 //kuo exper Y axis
//#define Z_AXIS_MOTOR_09 //kuo exper Z axis
//====== Kuo Uncomment ONLY ONE or NONE of below for geared extruders
//Don't forget to also send gcode to set e-steps as detailed earlier
//Reversion back from geared extruder requires sending M92 E280 & M500 to printer
#define SKELESTRUDER // Uncomment if you have a 3.5 ratio Skelestruder. Also applies the patches for load distances and Z height.
//#define BONDTECH_PRUSA_UPGRADE_MK3 //Kuo Uncomment for Bondtech MK3 extruder upgrade. 3:1 extruder. This also sets Z_MAX_POS 205.
//#define BONDTECH_PRUSA_UPGRADE_MK3S //Kuo Uncomment for Bondtech MK3S extruder upgrade. (Note the S!!!!) 3:1 extruder. This also sets Z_MAX_POS 205.
//#define EXTRUDER_GEARRATIO_30 //Kuo Uncomment for extruder with gear ratio 3.0.
//#define EXTRUDER_GEARRATIO_3375 //Kuo Uncomment for extruder with gear ratio 3.375 like 54:16 BNBSX.
//#define EXTRUDER_GEARRATIO_35 //Kuo Uncomment for extruder with gear ratio 3.5 like 56:16 Bunny and Bear Short Ears.
//====== Kuo E3D Volcano Support
//#define E3D_VOLCANO //uncomment to adjust Z_MAX_POS to accomodate 8.5 mm greater Volcano extruder height
//====== Kuo Slice Support
//#define SLICETHERMISTOR //uncomment for Slice Thermistor
//#define SLICEMAGNUM //uncomment to adjust MMU2S filament laod/unload distances for Slice Magnum
//====== Kuo extrude before unload filament
#define EXTRUDE_BEFORE_UNLOAD //uncomment to always extrude filament a short distance before unloading. Forms smaller tip.
//---------------------------- Kuo End of defines one normally needs to change ----------------------------
Postato : 11/02/2020 5:16 pm
vintagepc
(@vintagepc)
Utenti
I suspect it's not happy with your Z distance, there's some weirdness there surrounding how the Mk3S handles the changed Z distance over the standard Mk3.  (Mk3 needs a Z-height correction for the skelestruder, 3S does *not*) Symptoms are either the nozzle hitting the bed, or starting the search too high, depending on your particular combo of printer flavour and firmware Z-height.
The XY calibration should not need adjustments, I've run it with my own skelestruder without issue after servicing the heat bed.
Postato : 11/02/2020 5:30 pm
SpecialT
(@specialt)
Mh. i would say the nozzle stands perfekt above the bad. 1,5 mm. the weirdness ist that the printer worked yesterday, but after i upfated the firmware today it want calibrate the z-Axis.
Postato : 11/02/2020 5:35 pm
vintagepc
(@vintagepc)
Utenti
You could still be having the issue. I think they fixed the non-safe Z descent since I looked at it; bottom line is the PINDA is not triggering where the firmware expects it to.
Make sure you've flashed the correct variant to your printer (3S vs Mk3)
Recalibrate sounds familiar. I think the printer forces that if you change the printer type via flash.
Postato : 11/02/2020 5:43 pm
vintagepc
(@vintagepc)
Utenti
TBH I should say my memory is fuzzy here; Guy's done some fantastic work but I no longer run his firmware, for me stock firmware + load distance changes for skelestruder works absolutely fine with my 0.9 degree motors now that M350 is supported for X/Y/Z.
I do have it up on github for reference ( https://github.com/prusa3d/Prusa-Firmware/compare/MK3...vintagepc:Skelestruder-MMU2S?expand=1 for the differences with stock firmware) but I would not recommend using it because a) it's my test ground and I offer no support for it, and b) it's not updated regularly, if at all. I just use it as a working base into which I merge a selection of feature/dev branches for the end product.
Postato : 11/02/2020 5:52 pm
CybrSage
(@cybrsage)
How do you use the M350?
Postato : 11/02/2020 6:02 pm
SpecialT
(@specialt)
Okay i looked again into the firmware and i am using the correct config. I tried to upload again an run the wizard and the same Error shows up.
Very confused because yesterday it worked fine.
After i continued to the menu after the error showed up and wants to drive the stepper manually i saw that he is on 5mm + but actuelly stands 1,5mm above the heatbed.
so i think it has something to do with the wrong max Z-Hight for the z-Axis.
Postato : 11/02/2020 6:05 pm
SpecialT
(@specialt)
@cybrsage
i am using the terminal on my Octoprint
Postato : 11/02/2020 6:06 pm
vintagepc
(@vintagepc)
Utenti
Posted by: @cybrsage
Set steps per mm first, then do
 M350 X8 Y8
to set both X and Y to 8 microstep resolution.
Then M500 to save it to EEPROM.
Note this alters the steps/mm value to stay constant, e.g. if you drop from 16 microsteps to 8 (halving the resolution), it also halves the steps/mm count since your step size is now twice what it was.
Same general principle as for the extruder apply - don't go far above 100 steps/mm on X/Y, X/Y travel moves are much,much faster and the einsy simply can't keep up at higher travel speeds, leading to skipped steps. It definitely can't handle 200, but if you have a different pulley size on the motor then 110, 120 would probably still work.
Postato : 11/02/2020 6:17 pm
2 persone hanno apprezzato
SpecialT
(@specialt)
okey i have now set the z-axis height to 215mm and now he also does the z_axis calibration
So for my MK3S with all Taurus mods I need 215mm z-axis height. I now print the test cube and write the result.
Postato : 12/02/2020 11:56 am
SpecialT
(@specialt)
I'd say the print is pretty good. A little more adjusting the belt tension and the print options and then it should work fine.
The drivers were running at about 40-50 C°, so everything is ok.
If someone else has the PRoblem with the Z-axis calibration. Look, after the error occurred, in the menu of the manual Z-axis movement and if there is a positive value, it must be subtracted from the entered maximum value in the firmware.
Questo post è stato modificato 6 years fa da SpecialT
Postato : 12/02/2020 12:53 pm
vintagepc
(@vintagepc)
Utenti
Yeah, you should be able to get a little better out of it. I don't have any pictures on hand, but on my own skelestruder + 0.9 degree setup I get prints that look damn near perfect, except at the most extreme light angles
Postato : 12/02/2020 1:31 pm
SpecialT
(@specialt)
Yes, it's not optimized per se, but it's working. I was in a hurry and with the 0.2 mm option in the Prusaslicer I put full speed^^.
So I also see what temperature the drivers have.
Postato : 12/02/2020 2:36 pm
Jon
 Jon
(@jon-14)
Hi, been reading this thread for the past few hours and I want to upgrade the x&y steppers to get rid of some vertical artefacts. I'm looking at the moons 1.8 and the trinamic QSH4218-51-049 1.8 (not looking at 0.9 atm, sorry) and was wondering which one would be better for reducing vfas. And what extra things will I need? I have read that the moons will need another cable like these: https://www.amazon.com/gp/product/B07CBV8DVZ
But what about the trinamic ones? Sorry for lack of knowledge at the moment. Only just started considering upgrades.
Postato : 15/02/2020 12:32 pm
Pagina 45 / 54
