RE: Stepper Motor Upgrades to Eliminate VFA's (Vertical Fine Artifacts)
By any chance did you accidentally uncomment, but with a 1.8 degree motor installed?
//#define E_AXIS_MOTOR_09 //kuo exper EXTRUDER
Doing that with a 0.9 degree extruder motor would cause over extrusion. BTW, I don't recommend a 0.9 motor on a geared extruder due to risk of inadequate torque during rapid filament moves.
Looking back through the firmware, there are some missing #define EXTRUDER_GEARED.
Please download new copy and see if that helps.
May need to factory reset to get new microsteps to take effect.
Should show for 0.9 on xy and 1.8 on E, 3.5 skelestruder
Send: M503
Recv: echo:Steps per unit:
Recv: echo: M92 X100.00 Y100.00 Z400.00 E473.00
Recv: echo:UStep resolution:
Recv: echo: M350 X8 Y8 Z16 E16
BTW, 3.9.0 will have the homing reset bug fixed; there was a corner case that caused a buffer underflow in certain circumstances.
I wanted to say a big THANK YOU to everyone still making this firmware train stay alive. You guys are the reason why open source works so well.
It is greatly appreciated.
Grrrr. Word Press kept throwing errors when I was posting earlier. When I angrily pasted for the 5th time, I forgot to edit the e step value
Send: M503
Recv: echo: M92 X100.00 Y100.00 Z400.00 E490.00
xD know after i got my 1.8 stepper on the extruder and reuped your config the printer failed every time on XYZ calibration:
always on the z calibration where he moves to the bed and wants to check the 4 points.
calibration starts through the wizard.
Also he doent stops overe the marked location on the heatingbed where the Pinda should be.
The pinda has an offset of 5 mm to the left and 3mm to the front.(viewed from displayside)
//====== Kuo Uncommented def(s) below specify 0.9 degree stepper motors on x, y, z, e axis
//Motors used should be 1 amp or lower current rating to avoid overheating TMC2130 drivers in Stealthchop.
//Kuo recommended 0.9 degree motors for X, Y, or direct drive E are Moons MS17HA2P4100 or OMC 17HM15-0904S
#define X_AXIS_MOTOR_09 //kuo exper X axis
#define Y_AXIS_MOTOR_09 //kuo exper Y axis
//#define Z_AXIS_MOTOR_09 //kuo exper Z axis
//====== Kuo Uncomment ONLY ONE or NONE of below for geared extruders
//Don't forget to also send gcode to set e-steps as detailed earlier
//Reversion back from geared extruder requires sending M92 E280 & M500 to printer
#define SKELESTRUDER // Uncomment if you have a 3.5 ratio Skelestruder. Also applies the patches for load distances and Z height.
//#define BONDTECH_PRUSA_UPGRADE_MK3 //Kuo Uncomment for Bondtech MK3 extruder upgrade. 3:1 extruder. This also sets Z_MAX_POS 205.
//#define BONDTECH_PRUSA_UPGRADE_MK3S //Kuo Uncomment for Bondtech MK3S extruder upgrade. (Note the S!!!!) 3:1 extruder. This also sets Z_MAX_POS 205.
//#define EXTRUDER_GEARRATIO_30 //Kuo Uncomment for extruder with gear ratio 3.0.
//#define EXTRUDER_GEARRATIO_3375 //Kuo Uncomment for extruder with gear ratio 3.375 like 54:16 BNBSX.
//#define EXTRUDER_GEARRATIO_35 //Kuo Uncomment for extruder with gear ratio 3.5 like 56:16 Bunny and Bear Short Ears.
//====== Kuo E3D Volcano Support
//#define E3D_VOLCANO //uncomment to adjust Z_MAX_POS to accomodate 8.5 mm greater Volcano extruder height
//====== Kuo Slice Support
//#define SLICETHERMISTOR //uncomment for Slice Thermistor
//#define SLICEMAGNUM //uncomment to adjust MMU2S filament laod/unload distances for Slice Magnum
//====== Kuo extrude before unload filament
#define EXTRUDE_BEFORE_UNLOAD //uncomment to always extrude filament a short distance before unloading. Forms smaller tip.
//---------------------------- Kuo End of defines one normally needs to change ----------------------------
I suspect it's not happy with your Z distance, there's some weirdness there surrounding how the Mk3S handles the changed Z distance over the standard Mk3. (Mk3 needs a Z-height correction for the skelestruder, 3S does *not*) Symptoms are either the nozzle hitting the bed, or starting the search too high, depending on your particular combo of printer flavour and firmware Z-height.
The XY calibration should not need adjustments, I've run it with my own skelestruder without issue after servicing the heat bed.
Mh. i would say the nozzle stands perfekt above the bad. 1,5 mm. the weirdness ist that the printer worked yesterday, but after i upfated the firmware today it want calibrate the z-Axis.
You could still be having the issue. I think they fixed the non-safe Z descent since I looked at it; bottom line is the PINDA is not triggering where the firmware expects it to.
Make sure you've flashed the correct variant to your printer (3S vs Mk3)
Recalibrate sounds familiar. I think the printer forces that if you change the printer type via flash.
TBH I should say my memory is fuzzy here; Guy's done some fantastic work but I no longer run his firmware, for me stock firmware + load distance changes for skelestruder works absolutely fine with my 0.9 degree motors now that M350 is supported for X/Y/Z.
I do have it up on github for reference ( https://github.com/prusa3d/Prusa-Firmware/compare/MK3...vintagepc:Skelestruder-MMU2S?expand=1 for the differences with stock firmware) but I would not recommend using it because a) it's my test ground and I offer no support for it, and b) it's not updated regularly, if at all. I just use it as a working base into which I merge a selection of feature/dev branches for the end product.
How do you use the M350?
Okay i looked again into the firmware and i am using the correct config. I tried to upload again an run the wizard and the same Error shows up.
Very confused because yesterday it worked fine.
After i continued to the menu after the error showed up and wants to drive the stepper manually i saw that he is on 5mm + but actuelly stands 1,5mm above the heatbed.
so i think it has something to do with the wrong max Z-Hight for the z-Axis.
@cybrsage
i am using the terminal on my Octoprint
Set steps per mm first, then do
M350 X8 Y8
to set both X and Y to 8 microstep resolution.
Then M500 to save it to EEPROM.
Note this alters the steps/mm value to stay constant, e.g. if you drop from 16 microsteps to 8 (halving the resolution), it also halves the steps/mm count since your step size is now twice what it was.
Same general principle as for the extruder apply - don't go far above 100 steps/mm on X/Y, X/Y travel moves are much,much faster and the einsy simply can't keep up at higher travel speeds, leading to skipped steps. It definitely can't handle 200, but if you have a different pulley size on the motor then 110, 120 would probably still work.
okey i have now set the z-axis height to 215mm and now he also does the z_axis calibration
So for my MK3S with all Taurus mods I need 215mm z-axis height. I now print the test cube and write the result.
I'd say the print is pretty good. A little more adjusting the belt tension and the print options and then it should work fine.
The drivers were running at about 40-50 C°, so everything is ok.
If someone else has the PRoblem with the Z-axis calibration. Look, after the error occurred, in the menu of the manual Z-axis movement and if there is a positive value, it must be subtracted from the entered maximum value in the firmware.
Yeah, you should be able to get a little better out of it. I don't have any pictures on hand, but on my own skelestruder + 0.9 degree setup I get prints that look damn near perfect, except at the most extreme light angles
Yes, it's not optimized per se, but it's working. I was in a hurry and with the 0.2 mm option in the Prusaslicer I put full speed^^.
So I also see what temperature the drivers have.
Hi, been reading this thread for the past few hours and I want to upgrade the x&y steppers to get rid of some vertical artefacts. I'm looking at the moons 1.8 and the trinamic QSH4218-51-049 1.8 (not looking at 0.9 atm, sorry) and was wondering which one would be better for reducing vfas. And what extra things will I need? I have read that the moons will need another cable like these: https://www.amazon.com/gp/product/B07CBV8DVZ
But what about the trinamic ones? Sorry for lack of knowledge at the moment. Only just started considering upgrades.
