Stepper Motor Upgrades to Eliminate VFA's (Vertical Fine Artifacts)
Seite 37 / 54
Bunny Science
(@bunny-science)
RE: Stepper Motor Upgrades to Eliminate VFA's (Vertical Fine Artifacts)
I think I got it.
bool can_load was doing a default + 60 followed by -58 for Bontech_Prusa_Upgrade_MK3S
For all other extruders it feeds 8 mm further than it pulls out.
Added balancing load to sequence. It's in my repository now, or you can manually edit your copy of mmu.cpp to read as
static bool can_load()
    #ifdef SLICEMAGNUM //Kuo
      current_position[E_AXIS] += 67;
    #elif defined(SKELESTRUDER)
      current_position[E_AXIS] += 50;
    #elif defined(BONDTECH_PRUSA_UPGRADE_MK3S)
      current_position[E_AXIS] += 64;
    #else
      current_position[E_AXIS] += 60;
    #endif //Kuo ===
    plan_buffer_line_curposXYZE(MMU_LOAD_FEEDRATE, active_extruder);
      current_position[E_AXIS] -= 59;
      current_position[E_AXIS] -= 42;
      current_position[E_AXIS] -= 58;
    #else
      current_position[E_AXIS] -= 52;
    #endif //Kuo ===
    st_synchronize();
Veröffentlicht : 29/08/2019 10:18 pm
Bunny Science
(@bunny-science)
Might be best if you re-downloaded from my repo because you changed some other things during your tries.
Veröffentlicht : 29/08/2019 10:21 pm
Bunny Science
(@bunny-science)
ooops, I can't do simple math. It should be
  current_position[E_AXIS] += 66;
  #else
  #endif //Kuo ===
fixed in my repository.
Veröffentlicht : 29/08/2019 10:26 pm
CybrSage
(@cybrsage)
Thanks, I would give it a try a. I always read download, I don't trust myself enough. 🙂
Veröffentlicht : 29/08/2019 10:30 pm
CybrSage
(@cybrsage)
I lost my PC Internet connection so I will be doing this test later. Didn't want you waiting around for it.
Veröffentlicht : 29/08/2019 10:44 pm
Chocki
(@chocki)
Finished fitting my uprated PSU set to 26v output, Reverse Einsy case, heavier duty wiring.
Fitted STEPPERONLINE 0.9° OMC 17HM15-0904S motors to both X and Y axes and fitted BALITENSEN GT2 Timing Pulley 16 Teeth 5mm Bore, Width 10mm for GT2 Belt.
Now the rest of my printer is JLTX design parts, Skelestruder, Taurus X Axis, and Taurus Y axis.
The thing with Taurus Y axis is that the belt does not wrap around the pulley as much as a standard PRUSA drive, and with the BALITENSEN pulley the belt jumps the teeth during Y axis homing. I can get homing to work, but my belt tension is quite high.
Same configuration on the old LDO 1.8 motors and I never got a belt skip.
Firmware Guy-K2's as of 31/08/19
So these 0.9 OMC steppers just drive through and will cause the belt to jump hence the Y axis length errors some people are getting.
The Taurus Y axis configuration is more susceptible to jumping of the belt.
Diese r Beitrag wurde geändert Vor 6 years von Chocki
Veröffentlicht : 31/08/2019 11:02 pm
Bunny Science
(@bunny-science)
Just looked at the Taurus Y. Wow, that really engages a fraction of the motor drive pulley!
You might try a lower homing Y threshold to stop on a smaller resistance change, but I would worry about an axis that is so easy to skip teeth. It's going to have the same lowered tooth skip resistance during print operation.
Veröffentlicht : 01/09/2019 12:03 am
Chocki
(@chocki)
I've adjusted the belt to keep the tensioner as closed as possible whilst still being able to adjust the tension a little, this helps wrap the belt round more of the pulley.
This has allowed me to reduce the tension on the Y axis belt quite a bit, the whole thing is much smoother and quieter, but I'm not convinced I've got a good OMC motor on the Y axis as it sounds a bit buzzy, it's smooth enough to turn by hand but a bit noisy when moving at fast speeds.
Prints well, really well!, VFA's are history.
But I've got to get this replacement cover with fan for the PSU done ASAP, the noise from the fan is driving me nuts!.
The increased voltage is helping with heating times esp. the bed.
PID values for hotend were P17.6  I1.66  D46.45  now at 26v P13.02  I1.18  D35.91
Veröffentlicht : 01/09/2019 7:26 am
Bunny Science
(@bunny-science)
Chocki, two questions.
1. Did you set linearity correction to 1.130 for the OMC?
2. Were there problems with failed homing (other than belt jumping teeth) now that the firmware has more appropriate count limit for 0.9 motors?
Veröffentlicht : 01/09/2019 8:18 am
Chocki
(@chocki)
Linearity set to 1.130 and no other problems except the jumping teeth.
Here is a test qube, but I have the contrast high to show the difference and a bright led torch off to one side.
I think you can tell which one is with the OMC. The picture is really exagerating any slight imperfection, in reality it looks a lot better.
Veröffentlicht : 01/09/2019 9:09 am
Bunny Science
(@bunny-science)
Good to hear about no weird problems with homing. I think the latest firmware change will solve a lot of those problems. Your construction being so unusual is a nice edge case.
Nicely done so far as VFA reduction. All I see left is what looks like bearing noise. I could make those appear by increasing side pre-load on my bearings. It wasn't until I got my rod spacings to match the spacing that the bearings naturally preferred that the random stuff was minimal. Overall, I would say this is a success in improving your print quality already.
Veröffentlicht : 01/09/2019 9:28 am
Chocki
(@chocki)
It's thanks to you and all the time and effort you have put into this that we can print as well as this.
It is most likely bearing noise, as I did not really check spacing of rods etc when I rebuilt the printer this time, just did not have the time, now I know it all works, I can spend the time getting alignment perfect, and hopefully my hot end upgrade will arrive soon.
Veröffentlicht : 01/09/2019 9:45 am
CybrSage
(@cybrsage)
Posted by: guy.k2
  #else
  #endif //Kuo ===
I downloaded the firmware again and redid the needed uncomments, etc, like normal.  Here is a picture of where the filament stops for me, just barely peeking out of the PTFE tube.
I use a pass through PC4-M10 Festo, so the tube touches the top of the sensor, ensuring the filament does not get lost trying to enter the little hole for the sensor - which it enters without any issues (sensor triggers properly).  But then when it backs up, it pushes it too far out and it is no longer near the teeth, so it never pulls it back in.
I did a factory reset before the last update, but I will do it again now just to be sure.  But here is the picture.
Attachment removed
Diese r Beitrag wurde geändert Vor 6 years von CybrSage
Veröffentlicht : 03/09/2019 8:03 pm
Bunny Science
(@bunny-science)
I assume this is the top one feeding into the FESTO?
We should probably reduce the distance for the retract move. BUT....
What I don't understand is the filament tip in your pict is well above the Bondtechs. If it was just the Bondtechs retracting resulting in that position is would be about 1 cm out from PTFE end. The Bondtechs themselves can't drive the filament up further by themselves. Is the MMU2S also pulling back or did the filament simply shift position when you pulled it for the pict.
Veröffentlicht : 03/09/2019 8:16 pm
Bunny Science
(@bunny-science)
Cybersage let's have you do some adjustments to can_load in mmu.cpp
Where it now says...
    #else
    #endif //Kuo ===
Reduce the retract distance for Skelestruder until it no longer does excessive retraction. Something like...
      current_position[E_AXIS] -= 30; //was 42
If doing that or an even shorter distance doesn't change anything, there is something else that is causing the excess retract. If you find a good distance, let us know here and we'll update my firmware repository.
Veröffentlicht : 03/09/2019 8:23 pm
Bunny Science
(@bunny-science)
You should not need to do a factory reset when changing the retract distance constant. Just edit, compile and reflash.
I'm sure you did but #define SKELESTRUDER is uncommented in configuration_Prusa.h right?
Veröffentlicht : 03/09/2019 8:31 pm
CybrSage
(@cybrsage)
The hard reset did not change anything.  I will make the edits, and this time I will pay attention to what the MMU does.  You are right, it is surely being moved by the MMU since it is quite a bit above the gears.
I do not have the skelestruder, I have the Bondtech MK3S full upgrade (including the new body, filament sensor, etc.).  I will make the changes to the MK3S parts instead.
Veröffentlicht : 03/09/2019 8:32 pm
Bunny Science
(@bunny-science)
BONDTECH_PRUSA_UPGRADE_MK3S - I can't keep straight who which extruder.
Then adjust
#else
to a lower distance like...
current_position[E_AXIS] -= 40; /was 58
Veröffentlicht : 03/09/2019 8:36 pm
CybrSage
(@cybrsage)
My fault, I should have told you which I had.  Easy for me to remember only one, but hard for you to remember many.  My bad.
I already tried adjusting it to -30 and it still failed.  This time, I watched everything that could move.  It appears to stop being pushed by the MMU once it hits the sensor, which (by design) is a bit above the bondtech gears.  At this point, the gears should be pulling it but cannot.  The gears are on the entire time the MMU is pushing it, so it is ready to receive.
I just changed the settings for the += portion to these and am about to test (while keeping the -30, simply because I forgot to change it).
current_position[E_AXIS] += 86;  //was 66
Veröffentlicht : 03/09/2019 8:47 pm
Bunny Science
(@bunny-science)
I agree having it push further is the next adjust if it isnt' getting far enough down for the Bondtechs to grip.
Veröffentlicht : 03/09/2019 8:50 pm
Seite 37 / 54
