RPi Zero 2 W PrusaPrint Support
Strona 4 / 4
towlerg
(@towlerg)
RE: RPi Zero 2 W PrusaPrint Support
"lets say for exemple the one where you upload gcodes" So not actually stating specifically SD but if not where else. Generally GCode is streamed from Octoprint.
Opublikowany : 19/01/2022 1:43 pm
pcweber
(@pcweber)
I suppose that one could save, where I am almost certain that the pi does, in the /home/pi directory. Unless one has a different login; then under the different user directory is.
Stay safe and healthy, Phil
Opublikowany : 19/01/2022 2:04 pm
Mrak3D
(@mrak3d)
did anyone try klipper in this setup?
Is it worth and how to handle it?
thnx!
Opublikowany : 05/02/2022 11:37 am
Thelvaen
(@thelvaen)
Tried it with an other board, was working just fine with a Pi Zero2. And also, using the Serial port instead of the USB port will bypass the known issue with the Einsy Rambo provided by Prusa on the USB controller.
Opublikowany : 05/02/2022 11:59 am
pimogo
(@pimogo)
Hoping this is the correct place for assistance. SO i recently moved a working Raspberry Pi Zero 2 W from externally connecting via USB to one that connects via GPIO.  I followed this guide Link
After soldering the pins to the rasp pi zero 2 i installed it to the back of the einsy board, powered up the machine and under settings selected RPI Port = ON.
I'm able to login to octoprint no problem, but when connecting to the machine i get the following error:
State: Offline after error No more candidates to test, and no working port/baudrate combination detected.
Any ideas whats left for me to try? Thansk!
Here are images of the PI Zero 2
Opublikowany : 12/05/2022 4:16 pm
pcweber
(@pcweber)
Try this -
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-user-mods-octoprint-enclosures-nozzles/octoprint-state-offline-after-error-after-initial-setup/
Opublikowany : 12/05/2022 4:51 pm
pimogo polubić
pimogo
(@pimogo)
Yup that did it. Looks the guide i used was incomplete. many thanks!
Opublikowany : 12/05/2022 6:42 pm
ExtrudingThoughts
(@extrudingthoughts)
Is is possible update the printer's firmware from  the installed RPi Zero?  On this page https://help.prusa3d.com/article/octoprint-configuration-and-install_2182#configure-rpi-zero-w-gpio there is a comment that PRUSA is working on this.
Opublikowany : 23/07/2022 10:42 pm
oufledingue
(@oufledingue)
Hello there ! (kenobi style)
i installed my pi zero 2W in my prusa more than 2 hours ago and no message on the LCD
i managed to get the ip which has taken the Pi from my web router. When trying to connect to the web interface, i am on this
2 things coming to my mind :
  1. i tested the pi before inserting it. I mean it first boot was outside of the prusa. Can it come from that ?
  2. my soldering ? i am not very good at that. So might need a second try ?
thanks a lot for your help
Opublikowany : 02/06/2023 5:30 pm
oufledingue
(@oufledingue)
Posted by: @oufledingue
that was a soldering issue, everything is working fine now 🙂 i just launched my first print from prusaslicer>prusa link>mk3S
now time to work on how i can add a camera 🙂
Opublikowany : 03/06/2023 2:41 pm
Strona 4 / 4
