RE: RPi Zero 2 W PrusaPrint Support
"lets say for exemple the one where you upload gcodes" So not actually stating specifically SD but if not where else. Generally GCode is streamed from Octoprint.
I suppose that one could save, where I am almost certain that the pi does, in the /home/pi directory. Unless one has a different login; then under the different user directory is.
Stay safe and healthy, Phil
did anyone try klipper in this setup?
Is it worth and how to handle it?
thnx!
Tried it with an other board, was working just fine with a Pi Zero2. And also, using the Serial port instead of the USB port will bypass the known issue with the Einsy Rambo provided by Prusa on the USB controller.
Hoping this is the correct place for assistance. SO i recently moved a working Raspberry Pi Zero 2 W from externally connecting via USB to one that connects via GPIO. I followed this guide Link
After soldering the pins to the rasp pi zero 2 i installed it to the back of the einsy board, powered up the machine and under settings selected RPI Port = ON.
I'm able to login to octoprint no problem, but when connecting to the machine i get the following error:
State: Offline after error No more candidates to test, and no working port/baudrate combination detected.
Any ideas whats left for me to try? Thansk!
Here are images of the PI Zero 2
Try this -
Yup that did it. Looks the guide i used was incomplete. many thanks!
Is is possible update the printer's firmware from the installed RPi Zero? On this page https://help.prusa3d.com/article/octoprint-configuration-and-install_2182#configure-rpi-zero-w-gpio there is a comment that PRUSA is working on this.
Hello there ! (kenobi style)
i installed my pi zero 2W in my prusa more than 2 hours ago and no message on the LCD
i managed to get the ip which has taken the Pi from my web router. When trying to connect to the web interface, i am on this
2 things coming to my mind :
- i tested the pi before inserting it. I mean it first boot was outside of the prusa. Can it come from that ?
- my soldering ? i am not very good at that. So might need a second try ?
thanks a lot for your help
that was a soldering issue, everything is working fine now 🙂 i just launched my first print from prusaslicer>prusa link>mk3S
now time to work on how i can add a camera 🙂
