Revo Six on MK3S+ has extra stringing and oozing
Página 3 / 3
Rubin Starset
(@rubin-starset)
RE: Revo Six on MK3S+ has extra stringing and oozing
Flying Printer, any chance you would be willing to share your tweaked settings? I would specifically interested in the 0.6mm changes.
Additionally what's been your experience with bridging with 0.6?
Thank you!
Respondido : 29/11/2024 7:12 pm
Flying printer
(@flying-printer)
Sure, when I get home I’ll post the settings I use. Give me a day or two.
Respondido : 30/11/2024 5:16 am
Flying printer
(@flying-printer)
Rubin and Willo47,
Here's the settings I use and relevant details about my printer. MK3S running fw 3.11 in a LACK enclosure with a self designed air filtration system. Filaments are all kept in dry boxes with plenty of desiccant.
Most of my printing is with Overture brand PETG on the textured sheet. On the "Filament Settings" tab in PrusaSlicer I have my first layer temp. at 240 and other layers at 245, the bed temps are stock, retraction length is 1.2, "Keep fan always on" checked and "Enable auto cooling" checked. I usually try to keep the enclosure at about 90F/32C, so on larger prints I have to prop the door open a little.
For ASA I use PolyLite brand filament on the smooth sheet. On the "Filament Settings" tab I use 260 nozzle temp. for all layers, bed temp of 110 and I unchecked the "Keep fan always on" box. Enclosure temp of 110F/43C with the door closed.
I'll throw this one on here even if not many people use it. For PP I use FormFutura Centaur on the smooth sheet with clear polypropylene packing tape on the bed. First layer nozzle temp of 235 and others at 240, bed temps of 85 for first layer and then 80 for others. "Keep fan always on" checked and "Enable auto cooling" checked. Fan speed max and min are 70% and disabled for first 2 layers. Max volumetric speed is 4 mm3/s. No retraction or lift while retraction. "Wipe while retracting" is disabled.
After looking at my settings, I was kind of surprised and how few I changed. I thought there were more. Hope this helps.
Respondido : 02/12/2024 3:51 pm
1 les gusta
Página 3 / 3
